How-To: Lower diffuser fascia & GT500 mud flap install
Old Sep 29, 2010 | 04:55 AM
Overboost's Avatar
Originally Posted by 2011 GT
Steve:
Looks great! Congrats on the install!
Did you purchase them online from Ford? I am searching on Fordparts.com and FordAccessories.com, but it won't return any results with the mudflap part #'s... any idea?
Also, do you need to have the GT500 diffuser, or will the flaps work with the "regular" GT lower facia?
Thanks,
Thanks Andy.
To answer your questions:
- I purchased mine from the dealer I bought the car from. I got them just under list price for each item. I took those numbers right off of the bags listed in Dan (montreal ponies) thread, and the dealer pulled them up without issue. Try another site like Tousley Ford and see if that works.
- You can use the mud flaps on a regular GT rear fascia. I decided to do it all at once, since you have to pull those screws to remove the fascia and diffuser anyways.
Old Sep 29, 2010 | 02:33 PM
Big Poppa's Avatar
I think the mud flaps are a little small to be effective. I wish someone would make some like the ones I had on my '05.
Old Nov 7, 2010 | 06:43 AM
Big Papi's Pony's Avatar
Well after seeing it installed on a base 5.0 at a car show 2 weeks ago I have jumped in the pool on this one as well. Picture difference doesn't do it justice you have to see the difference in person night and day compared to the stock rear valence. I said I was done for the year with my mods but I lied.
Old Nov 8, 2010 | 12:37 AM
stangfoeva's Avatar
MOTM Committee Member
Old Dec 22, 2010 | 02:38 PM
tehMoose's Avatar
My diffuser came in yesterday, splash guards came in today. Hoping to get them installed this weekend.
Thanks for the info supplied overboost!
Old Jul 28, 2011 | 07:57 AM
FastRedPonyCar's Avatar
Thought I would bump this thread seeing as to how I finished my front/rear fascia installs this week.
I read through the Roush instructions but decided to just wing it. Break the 2 white tabs off (the new fascia comes with new white tabs) Pull the 2 large push pins out and the 2 push pins on each outer edge of the bottom of the fascia, remove the 3 screws by the rear tire (I used a tiny ratchet w/phillips head attachment and got them out without removing the wheel) and then just peel the bumper away from the chassis.
This exposes all the push pins and screws holding the fascia on. Once they're removed and the wiring harness plugs (2 of them I think per side) are popped out, the fascia will pull off.
I didn't even bother to pop the trunk and start unhooking stuff. That was going to be a last ditch step.
New one snapped in without too much trouble but yeah those center tabs in the license plate area just did not want to go in all the way. I tried fanagling from every angle and still no luck. Last option was to try and push them in with a flat head screwdriver but didn't want to risk breaking anything or chipping paint.
And the Front CS/Boss fascia/splitter. The front fascia was SO easy to install but the boss splitter was a chore. Getting it lined up and then all those holes drilled was pretty tedious. I'm surprised that ford didn't implement any type of alignment hole or tab system to ensure it's perfectly straight.
Only thing now is whether to install the saleen front grille and tri bar pony badge or leave the grille as is. I already have the tri bar badge and grille mounting hardware. $220 for a grille though is just.... man that's a lot of $$ for just a grille.
Old Jul 28, 2011 | 08:35 AM
Stangpilot007's Avatar
Wow! That looks great with Candy Red. After seeing Steve's in person I further love the look of the OEM foglights and grille with the GT/CS fascia.
Old Aug 8, 2011 | 09:36 AM
99mstng's Avatar
Another bump w/pics from my install . . .
The rear isn't that bad just take your time and follow the Roush instructions. If you are doing the splitter and CS front install the splitter to the CS front OFF the car. Makes it so much easier and then when you install all there is are 6 holes to drill under the car instead of 30 or so.
Rear with Roush exhaust and 18x10 OE style rims and 295 series tires
Front with Roush grille and tri-bar pony emblem. Grill is a PIA to install (removing the old one is the hardest part).
Old Aug 8, 2011 | 10:32 AM
Another better shot of the front/rear. Not shown in these pics but I also put the GT500 splash guards on the rear.
Old Aug 8, 2011 | 07:56 PM
c0achmke's Avatar
I say keep the stock grill everyone is doing the other. Be different and don't change that's what I did!
Old Aug 8, 2011 | 08:45 PM
I'm strongly considering it (simply due to the fact that it's the least expensive route!) but every time I see digitalsynapse's car I want that saleen grille
A much cleaner/sleeker look IMO.
Old Apr 9, 2012 | 12:56 AM
HizliBullet's Avatar
If you've got questions or concerns, let me know and I'll try to elaborate. I have some other pictures that need tweaked and I'll add them to the first post.
And yes, a set of 4" tips would look wonderful in there.
sorry to bump old thread, so GT500 mud flaps fit '11 GT? (AR3Z-16A550-AA)
Old Apr 9, 2012 | 04:38 AM
Overboost's Avatar
Yep, they fit.
Old Apr 11, 2012 | 09:08 PM
RobDis's Avatar
Word on the middle part of the diffuser being the hardest part to remove and get back on correctly. I took my whole bumper cover off to do this. Wish I would have left it on, may have been easier. Call me crazy but I took a piece of foam and a rubber mallet/persuasion device to get the middle back in. But it worked and no damage! But the end result is worth it, really dresses up the rear nicely!
Old Apr 15, 2012 | 10:03 AM
JPMotorSport's Avatar
Looking to get my GT500 rear diffuser soon, been doing research and a lot of people have been saying to leave the rear bumper cover on for leverage to pull off the OEM diffuser. Good to hear the feedback for when I have to install, don't want to have to deal with pulling off the bumper!
Old Apr 15, 2012 | 04:30 PM
RobDis's Avatar
Actually removing the bumper was the easiest part! Putting it back on as well. Definitely worth it though. Its a subtle change but noticeable.
Old Apr 18, 2012 | 09:38 AM
gtman2012's Avatar
Looks great, I think this is going to me my next mod
Old May 15, 2012 | 09:24 PM
installed my gt500 mud flaps today, didnt know i had to clip it to the bumper, scratched the facia little bit..came to work noticed it should fit tighter so gonna go adjust it at home
Ecostang
Nov 3, 2022 08:50 PM
Diode Dynamics
Jun 12, 2018 03:26 PM
LuiG31
Ecoboost
Jul 20, 2015 01:25 PM
