Head light Swap
Old Jan 8, 2014 | 10:15 PM
Kript2night's Avatar
Head light Swap
I'm wanting to put the 13' head lights on my 2010 GT i found a good deal on a set. I was wondering if anyone has done it yet and are they a direct swap plug an play. Any advice would be great before i pull the trigger..
Old Jan 8, 2014 | 11:10 PM
southcarolina12's Avatar
the plugs are different. theres a online company that sells a harness to do the swap but i dont remember the name of the company.
Old Jan 8, 2014 | 11:48 PM
Ok Thanks.. Anyone try this yet
Old Jan 9, 2014 | 12:12 AM
You can do it. It might take a little splicing, but purchase them ASAP before the deal is gone, then figure it out later. It can be done though.
Old Jan 9, 2014 | 01:54 AM
Kool deal.. I have factory HID's an projectors. will my bulbs and stuff work with the 2013 light..
Old Jan 9, 2014 | 06:28 AM
your bulbs will work in them. the headlights dont come with bulbs? even when you buy a replacement hid headlight assembly from ford they come with new bulbs and a ballasts.
Old Jan 9, 2014 | 07:13 AM
No the ones i'm looking at dont come with bulbs or ballest thats why im getting them cheap. However if my bulbs and ballast will fit its no a issue.
Old Jan 9, 2014 | 07:18 AM
stang8psi's Avatar
My self and plenty others on other forms have done the swap, I will provide you the website that makes all the required harnesses for either going from halogen h13 headlights to factory 2010-2012 HID and the harness to go to halogen h13 to 2013-2014 hid headlights. There us also a new plug for 2010-2012 factory equipped hid headlight owners to switch to the 2013-2014 headlights without having to cut any wires.. here are all the links to the company..
2010-2012 factory halogen headlights to 2013-2014 headlight harness.
http://m.projectoretrofits.com/site/...oretrofits.com
2010-2012 factory halogen headlights to 2010-2012 OEM hid harness
2010-2012 factory equipped hid to 2013-2014 hid headlights adapter.
He also sells the headlights and harness as a package starting at $750 and up
Old Jan 9, 2014 | 07:22 AM
Thank you for the help.. I have the factory HID on my 10'
stang8psi's Avatar
If you are a factory hid projector equipped car than a your headlight bulbs (d3s) will fit and so will the ballasts.. the only thing that will need re wired is the turn signal.. the bulb in the 2013-2014 is different than the 2010-2012 hid cars . It is a simple wire swap with the same 3 wires just need to cut and solder a new 7444 bulb harness.
Old Jan 9, 2014 | 07:25 AM
Ok thank you very muck..Do you have any pics with the 13' light on
Old Jan 9, 2014 | 07:35 AM
stang8psi's Avatar
Yes.
Old Jan 9, 2014 | 07:49 AM
theres some on ebay for $150 each. really good deal since they are like $1,200 each from ford.
Old Jan 9, 2014 | 08:53 AM
stang8psi's Avatar
Problem is they are broken tabs, bare units (150-200 for ballasts and bulbs per side) and scratched lenses.. so $150.00 plus 150-200 is now $350 for broken tabs and or damaged lenses . Than double for both sides is now 700.00 for a set.. the links I provided if you contact the guy he does the headlights starting at 750 and they are not damaged ones and he includes the harness.
Old Jan 9, 2014 | 10:32 AM
06blackvertstang's Avatar
Yes.
Great looking car man. Those wheels have a really nice offset and look good with the stance of your car. And the headlights look nice too haha
Old Jan 11, 2014 | 06:25 AM
Sir, I looked at your site linked, and I can't seem to find the package where he sells everything for like 750? So you're saying if I have stock 2012 HIDs already, he has a package where everything is included and will work for a 2013 oem hid package by just plug and play, including the turn signals?
Old Jan 13, 2014 | 09:18 PM
stang8psi's Avatar
correct.. contact him. He was selling them on another forum for 750.. I bought my 13 headlights from this site from a member and bout the 75.00 plug for the new 13 lights to convert my 11 oem hid pigtail to the new 16 pin. The turn signal harness he also sells.. I just bought new 7440 plugs and soldered my own harness instead of buying a plug n play kit. It saved money. when you buy the harness for either a oem equipped car or a halogen car there are detailed instructions on doing the install.
FromZto5
Sep 30, 2015 05:28 AM
DEPUTY62
Sep 12, 2015 11:12 AM
14Glassback
Sep 11, 2015 04:50 PM
earl610
Sep 7, 2015 11:57 AM
