Head light Swap
I'm wanting to put the 13' head lights on my 2010 GT i found a good deal on a set. I was wondering if anyone has done it yet and are they a direct swap plug an play. Any advice would be great before i pull the trigger..
the plugs are different. theres a online company that sells a harness to do the swap but i dont remember the name of the company.
Ok Thanks.. Anyone try this yet
You can do it. It might take a little splicing, but purchase them ASAP before the deal is gone, then figure it out later. It can be done though.
Kool deal.. I have factory HID's an projectors. will my bulbs and stuff work with the 2013 light..
your bulbs will work in them. the headlights dont come with bulbs? even when you buy a replacement hid headlight assembly from ford they come with new bulbs and a ballasts.
No the ones i'm looking at dont come with bulbs or ballest thats why im getting them cheap. However if my bulbs and ballast will fit its no a issue.
My self and plenty others on other forms have done the swap, I will provide you the website that makes all the required harnesses for either going from halogen h13 headlights to factory 2010-2012 HID and the harness to go to halogen h13 to 2013-2014 hid headlights. There us also a new plug for 2010-2012 factory equipped hid headlight owners to switch to the 2013-2014 headlights without having to cut any wires.. here are all the links to the company..
2010-2012 factory halogen headlights to 2013-2014 headlight harness. http://m.projectoretrofits.com/site/...oretrofits.com 2010-2012 factory halogen headlights to 2010-2012 OEM hid harness http://m.projectoretrofits.com/site/...oretrofits.com 2010-2012 factory equipped hid to 2013-2014 hid headlights adapter. http://m.projectoretrofits.com/site/...oretrofits.com He also sells the headlights and harness as a package starting at $750 and up |
Thank you for the help.. I have the factory HID on my 10'
Originally Posted by Kript2night
(Post 6740948)
Originally Posted by stang8psi
(Post 6740952)
If you are a factory hid projector equipped car than a your headlight bulbs (d3s) will fit and so will the ballasts.. the only thing that will need re wired is the turn signal.. the bulb in the 2013-2014 is different than the 2010-2012 hid cars . It is a simple wire swap with the same 3 wires just need to cut and solder a new 7444 bulb harness.
4 Attachment(s)
theres some on ebay for $150 each. really good deal since they are like $1,200 each from ford.
Originally Posted by southcarolina12
(Post 6740968)
(Post 6740963)
Yes.
(Post 6740952)
Originally Posted by FromZto5
(Post 6741910)
Sir, I looked at your site linked, and I can't seem to find the package where he sells everything for like 750? So you're saying if I have stock 2012 HIDs already, he has a package where everything is included and will work for a 2013 oem hid package by just plug and play, including the turn signals?
correct.. contact him. He was selling them on another forum for 750.. I bought my 13 headlights from this site from a member and bout the 75.00 plug for the new 13 lights to convert my 11 oem hid pigtail to the new 16 pin. The turn signal harness he also sells.. I just bought new 7440 plugs and soldered my own harness instead of buying a plug n play kit. It saved money. when you buy the harness for either a oem equipped car or a halogen car there are detailed instructions on doing the install. |
