Engine Cover with SR Performance Strut Tower Brace?
Old Apr 17, 2015 | 10:28 AM
firstang001's Avatar
Hello,
I am wanting to get the engine cover for my 2013 3.7. I was almost about to pull the trigger and then realized that I have a SR Performance strut tower brace installed . Which makes think. If the engine cover fit under the tower brace? If it does, can I install the cover without removing the tower brace?
P.S. I do not want to take the tower brace off and install the cover as the nuts holding the front coilovers will just fall off and is hard to re install it with out messing up alignment.
Thank you for all the advice and help!!
Old Apr 17, 2015 | 12:39 PM
TripleBlack14's Avatar
I can't speak to your tower brace, but when I replaced the plenum cover on my '14 GT I had to remove my stock brace. I might have been able to finesse the cover without taking off the brace, but it's only 8 bolts and made life so much easier.
Old Apr 18, 2015 | 07:30 AM
cdiaz1069's Avatar
I have both. It will fit, and I think you will be able to leave the brace on. Hope this pic helps.
Old Apr 18, 2015 | 08:23 AM
CCTking's Avatar
Youll just have to slide the cover into place under the bar, line up the holes and bolt it down. Shouldnt be hard but take your time and it will go on without any issue
Old Apr 18, 2015 | 06:11 PM
Thank you guys, I really appreciate the advice and the picture! !! I think i will go for it!!
GLOCKer
Aug 13, 2015 09:55 AM
Coastie585
Aug 3, 2015 10:29 AM
Jul 30, 2015 06:47 AM
roushcollection
Jul 28, 2015 02:08 PM
MADSCOTSMAN
Jul 22, 2015 04:57 PM
