BBS LM rep wheels mounted
Old Jan 10, 2012 | 03:58 AM
neema's Avatar
Thought I'd share. Linea Corse Lemans 19x10 et43 on all four corners with 285/35/19 Kumho Ecsta XS tires. 15mm spacers needed up front to clear the brembos. 1.8º of camber up front. The car is lowered around 2". kw clubsport coilovers. Better pictures coming soon.
FYI these should fit really well with non-brembo cars, assuming they have more brake caliper clearance. you may not even need a spacer at all.
Old Jan 10, 2012 | 04:20 AM
HizliBullet's Avatar
Lookin sweet man, I'm making the second pic my iPhone wallpaper
Old Jan 10, 2012 | 04:45 AM
Scrape's Avatar
Very Nice.
Old Jan 10, 2012 | 05:22 AM
MRGTX's Avatar
Can't go wrong with BBS... very nice. Formal looking...good choice!
Old Jan 10, 2012 | 05:34 AM
Evil_Capri's Avatar
Outstanding!
Old Jan 10, 2012 | 11:27 AM
Flagstang's Avatar
Spam Connoisseur
I got هَبوب‎ed
a bronze set of those on a black stang would be more then sexy
Old Jan 10, 2012 | 11:29 AM
POS VETT's Avatar
What is the smallest lateral clearance between the wheel and the Brembo caliper after a spacer ?
Old Jan 10, 2012 | 02:48 PM
06GT's Avatar
niiiiiiiiiiiiiice
Old Jan 10, 2012 | 09:34 PM
neema's Avatar
there's probably 2.5-3.5mm of clearance max between the spacer and caliper. if i found a 13mm spacer, i'd try it, but it would be very tight. i wish the brembo calipers were mounted more inboard
Old Jan 11, 2012 | 06:48 AM
POS VETT's Avatar
A 13-mm spacer is basically half an inch. Did you have problem with thread engagement ? Do you know how many turns of lug nut until it touches the wheel ?
One solution is to use extended-tip lug nut. The extension is about 3/8" or 10 mm; not quite the 15 mm that the spacer took, but it would help.
Old Jan 12, 2012 | 12:47 PM
neema's Avatar
the h&r spacers i got come with replacement studs, which gives plenty of thread for the lug nuts. There isn't close to enough thread engagement with the stock lugs. funnily enough the new studs are the same lenght as the stock studs, they just don't have the little threadless engagement tip (best name i could come up with) at the end of the stud.
Old Jan 12, 2012 | 01:24 PM
POS VETT's Avatar
Did stud replacement require removal of the wheel hub ?
Old Jan 14, 2012 | 01:12 AM
neema's Avatar
no, no removal of the hub necessary, but because i used a ball joint separator (harbor freight) to go easy on the hub bearings, I removed the caliper and rotors. otherwise you can just hammer out the studs and use an open ended lug nut to pull in the new ones.
Old Jan 14, 2012 | 01:29 AM
t-fatty's Avatar
I love those style wheels and white was my first choice of colors.
Old Jan 14, 2012 | 03:36 AM
kn7671's Avatar
Those are going to be so much FUN cleaning after they get some dirt, water, and brake dust build-up.
Looks good, but you're gonna be kicking yourself when it comes to cleaning time.
Old Jan 15, 2012 | 08:48 AM
neema's Avatar
a few more pictures. sorry for more iphone pics. i still need to pull out the good camera
Old Jan 23, 2012 | 10:32 PM
JPMotorSport's Avatar
O, real tasty! They definitely give the car a euro look.
Old Jan 24, 2012 | 06:06 PM
PJRManagement's Avatar
Currently a Corvette Owner!
Wow, those look good! What an agressive stance. Great wheels, and excellent tire width for front and rear! Very nice!
Old Jan 25, 2012 | 01:12 PM
Big Poppa's Avatar
They really compliment the car.
Old Jan 25, 2012 | 01:23 PM
m4a1mustang's Avatar
I like it!
Kestral
Sep 5, 2015 11:50 PM
GLOCKer
Aug 13, 2015 09:55 AM
glo106
Aug 11, 2015 08:29 AM
