Anyone welded in their cat back exhaust?
Old Jun 10, 2011 | 09:23 PM
c0achmke's Avatar
Wonder if anyone has had theirs welded in to cut down on exhaust leaks?
Old Jun 11, 2011 | 07:16 AM
nite's Avatar
Not a good idea, as it will be PITA to remove when/if you need to.
Use quality band clamps and you won't have any leaks.
Old Jun 11, 2011 | 07:22 AM
karman's Avatar
+1 on that.
Just use good band clamps.
Sometimes it take a little adjusting, but you can do it.
Old Jun 11, 2011 | 07:28 AM
c0achmke's Avatar
Cool thanks for the advice.
Old Jun 11, 2011 | 10:31 AM
908ssp's Avatar
I plan on welding mine in. Should last 10 years and then if I still have it, it will be cut out so who cares. Welding is lighter, tighter and stronger and less likely to drag around road kill.
Old Jun 11, 2011 | 12:05 PM
Ivan 5.0's Avatar
One band clamp had to be welded when my exhaust was installed.
Old Jun 11, 2011 | 07:53 PM
going for broke's Avatar
I helped my brother in law remove the aftermarket exhaust on his vette and although it was a pain it came off fine and we were able to re-use the headers.
I would just make sure they don't get crazy with the beads of weld. His exhaust also had clamps which I found odd but it didn't leak thats for sure.
Good Times
Aug 29, 2015 10:18 AM
Mackitude
Aug 13, 2015 01:05 PM
Smaxon
Which is Better
Aug 12, 2015 01:39 PM
tony2014mustang
Aug 9, 2015 03:04 PM
