AMR Wheels and center caps options
Old May 9, 2012 | 08:49 AM
Dineau's Avatar
Anyone here has been able to find a replacement center cap for those AMR wheels.
Seen some posts reporting that the tri-bar pony would fit but no real evidence of it actually fitting..
Old May 9, 2012 | 10:37 AM
jsimmons's Avatar
They're "large" caps at 2.5 inches.I have a plan for mine that involves modifying the AM caps, but only because I can't find caps I want, and I'm not about to $150-200 for tri-bar-pony or FRPP caps.
Old May 9, 2012 | 10:52 AM
RobDis's Avatar
I heard that the 03 Mach 1 center caps would work. I know where there is a set of take offs near me. I will try to go by there today and see if they fit. They are the tri-bar pony caps. I will also get a part number if they fit.
Old May 9, 2012 | 11:08 AM
Dineau's Avatar
Great keep us updated on your findings...
Old May 10, 2012 | 07:07 AM
bones302's Avatar
I found that generic caps from fleabay work. then I can have whatever gel dome decals I want made up. cost me $20 for caps and $20 for decals.
Old May 10, 2012 | 09:05 AM
jsimmons's Avatar
What do you mean by "generic caps"? Got a link?
Old May 10, 2012 | 10:09 AM
bones302's Avatar
hmmm. something like this:
http://www.ebay.com/itm/MERCEDES-BEN...1b674d&vxp=mtr
these are generic, you can probably contact the seller for a 2 1/2 inch set
and then a gel decal like this:
http://www.ebay.com/itm/Mustang-Whee...e6c184&vxp=mtr
I did mine a year ago, so I don't remember exactly who I bought them from. Probably a little bit cheaper back then.
Old May 10, 2012 | 06:50 PM
RobDis's Avatar
After close inspection of the 03-04 Mach 1 wheels the center caps are exactly the same size as the AMR center caps. I didn't not try a fit test as I would have had to remove the wheel to get it back off. But they are the exact same size. I have included pictures of the actual center cap as well as the rear of the cap for part numbers.
Attached Thumbnails AMR Wheels and center caps options-p1000597.jpg   AMR Wheels and center caps options-p1000599.jpg
Old May 11, 2012 | 07:01 AM
KonaBlu's Avatar
I bought a set of the Tri-Bar Pony caps for my AMR wheels they do not fit. While they are 2.5 in size they are short and don't lock into place. I have contacted AMR via email requesting more information on center caps that do fit that they sell and have waited more than a week with no response. I like their products but it seems the only way to get them to respond to you is if you call them. Even when I ordered my wheel kit I could not get an email response.
Old May 11, 2012 | 07:07 AM
RobDis's Avatar
Where did you get the center caps? Are they Ford center caps or aftermarket?
Old May 11, 2012 | 07:13 AM
bones302's Avatar
yes, you have to look at the depth of the caps as well in order to make sure they are the same. I remember I had to dremel off some tabs on the inside of my generic caps in order for them to lock properly.
Old May 11, 2012 | 08:23 AM
KonaBlu's Avatar
I ordered them from CJPonyParts they are part number M1096K. They were the cheapest for this cap at 25 bucks a piece. They look awesome in the wheel I was really disappointed when they wouldn't lock in. Depth is important that is why I emailed AMR asking which caps they sell fit these rims.
Old May 13, 2012 | 11:33 PM
Wades GT's Avatar
They fit just fine
Old May 14, 2012 | 12:19 PM
RobDis's Avatar
Originally Posted by Wades GT
They fit just fine
Thank you! I didn't measure the depth but judging just by sight they seemed like they would work. I was going to test fit one when I went back home this week and then post a picture of that. But the bad part is I checked on Ebay and the only set I could find were $125. I can only imagine how much they cost from the dealership.
Old May 14, 2012 | 02:31 PM
KonaBlu's Avatar
They don't fit the Machined AMR Wheels. They are to short.
Old May 14, 2012 | 04:33 PM
GtStang4's Avatar
I have the same issue with a set of Steeda Q1 rims. Anyone have experience with those?
Old May 15, 2012 | 01:14 PM
05-1947's Avatar
This sounds similar to the 17x10.5 Reps I purchased for my Cobra. I had to wrap the centercap with electrical tape and then push it in the wheel. Maybe give that a shot as it worked for me.
Old May 26, 2012 | 08:45 AM
RobDis's Avatar
I tried the 03-04 Mach one center caps and they indeed do not fit. Looks going with a customized American Muscle center cap or generic cap is going to be the way to go. The stock caps for the Mach 1 could possibly be modified to fit but I don't have a set to experiment with and at $125 a set I don't think I will be buying some just to cut and grind on for fun! LOL
Diode Dynamics
Jun 12, 2018 03:26 PM
Jul 17, 2015 05:40 PM
