2013 raxiom headlights
Old Jun 10, 2013 | 11:57 AM
mikeyt03's Avatar
Can't say I care for these too much. I would have preferred that it retained the stock LEDs along with the halo
Almost did that with the oracle kit. I don't mind the new housing. Not the best, but I like them for sure.
Old Jun 10, 2013 | 01:20 PM
Dhawk1313's Avatar
I'm digging it man. Makes the front end look so menacing
Old Jun 10, 2013 | 05:42 PM
mikeyt03's Avatar
I know! When I drive around at the beach people always point at my headlights now.
Old Jun 11, 2013 | 08:59 AM
TheDivaDanielle's Avatar
I hope it's for a good reason.
Old Jun 11, 2013 | 09:10 AM
mikeyt03's Avatar
I don't think there is a single person that would not like my front end.
Old Jun 11, 2013 | 11:09 PM
jp1seattle's Avatar
I don't know if I would do that, but I'll have to admit your front end looks pretty good.
Old Mar 7, 2014 | 07:21 PM
pctek's Avatar
I am about to purchase a 2014 GT with the factory HID's. I've been looking at the Raxiom Halo's as a modification. What I cant get an answer to is what happens with my factory turn signal/Daytime Running lights? I thought they were LED's since they appear lime green when the car is running and amber when the turn signal is used, but looking at my manual it says it's a bulb. Does the Raxiom halo assembly use my stock turn signal lamp and assembly? Can the Halo and LED strip be setup to act as DRL's? or should I just leave the stick headlight assembly as is?? Thank you for your comments.
Old Mar 8, 2014 | 06:55 PM
mikeyt03's Avatar
Your daytime running lamps are led. Your turn signal is a bulb. The raxioms use the oem bulb for the turn signals. There is a led strip in the raxioms that act as the new daytime running lamps. The is no way to retain the factory led stripes.
Rando
Aug 25, 2021 11:12 AM
JonsMustang
Mar 5, 2016 05:44 PM
ricky1728
1994-2004 V-8
Sep 28, 2015 10:16 AM
