2013 LED Fogs fit?
2013 LED Fogs fit?
I have a 2012 5.0L. Wondering if the 2013 fogs will fit on my 5.0L. I Am talking about the upper fog lights with led bulbs in them.
IF so what is the pricing? I remember seeing a retrofit thread but cant find it.
I'm guessing it wont- just because the grille is different. And not sure on the wiring difference to support the LED in the 2013s. If all you want is matching HID light output- just get a different bulb for $30-40. Plug and Play.
I had HOEN in the mustang and now have them in my MKZ.
Have been pretty satisfied with them.
Hoen:
http://www.hoen-usa.com/fog.htm
Hoen:
Without taking a physical measurement, it seems like the fog light might actually fit the 2011/2012 grill just fine. Attached is a close pic of the fog light. I was at the NY auto show yesterday, one of the main things I was checking out were the fogs, the hood vents & the rear axle girdle/cover for the boss302 witch does indeed have fill & drain plugs.
I had hid retrofit on my 07GT on the fogs. They were great for mountain driving, however they blinded everyone on normal roads. The led fogs should be a good mix of the two, meaning good for mountain roads, but also good in regular driving.
We have the 13/14 LED fog lights (new OEM take off) in stock for $229.99 per set.
http://www.starkey-products.com/2013...led-fog-lights
We also have the proper conversion wiring to convert from an H10 connector (found on 05-12 GT models) to the proper connector for the LED lamps.
Jason
Jason
I have a '11 stang and just recently picked up a set of '13/14 fogs off ebay and a conversion wire harness from Starkey. The wire harness is supposed to arrive today. Ill post up a review once I have everything installed this weekend
Jason
Jason
Very good prices and customer service and High quality harness
