2013-14 headlights and foglights
I haven't had personal experience with the head lights, but the fog lights will not fit without modification.
In 2013 the foglamps are a different size, and they mount differently than 2012. But we have several customers purchase sets of the 13' LED lamps and retrofit them to 2010-2012s.
Jason
Jason
the headlights will fit, but you need to buy special connectors and rewire a couple of things to make the DRLs work. the foglights will not physically fit without significant modification because they are much thicker then the 10-12 fogs due to the heatsinks for the LEDs.
I am not aware of anyone who has done the fog light retrofit but quite honestly just throwing a 5000k HID system into the fogs will give you the same results.
the headlights will fit, but you need to buy special connectors and rewire a couple of things to make the DRLs work. the foglights will not physically fit without significant modification because they are much thicker then the 10-12 fogs due to the heatsinks for the LEDs. I am not aware of anyone who has done the fog light retrofit but quite honestly just throwing a 5000k HID system into the fogs will give you the same results.
Ok. I can scrap the idea about the fog lights, no big deal. I really like the '13 headlights though. Do you know where I can get the special connectors and how much the headlights run?
http://www.projectoretrofits.com/app...s/show/3841297
here is the harness
here is the harness
