2013-14 Fog Light Kit, GT/CS Style
I did a factory fog light delete when I changed grilles on my base GT and have been searching for an alternative fog light option. I'm wondering if anyone has used this kit and how they liked or disliked it. Looks to be all plug and play.
http://www.latemodelrestoration.com/item/LRS-15200CSA-K/2013-Mustang-Fog-Light-Kit-California-Special-Style
If there is a similar or better performing kit out there, somebody please point me in the right direction! Thanks
Fog lights
http://pages.ebay.com/motors/link/?nav=item.view&id=181357322459&alt=web
I know you've already ordered it, but the only issue I have had with it is its color and brightness. The stock HID headlights are way brighter and whiter than these fogs since they are a normal halogen bulb and kind of yellowish. I also swapped the GT/CS grilles but I retained the stock fogs as well. only downside has been the halogens.
Looks great.
http://www.starkey-products.com/hid-kits-13-14/
I still have my original OEM fog lights, but mounting them behind my Roush grille just doesn’t visually work for me at the present.
http://www.levittownfordsupercenter.com/index.php
I bought the California Special Upper and Lower Grilles. You can find my install here:
https://themustangsource.com/forums/...ht-mod-531048/
I bought the same ford kit DR3Z-15200-AA from my local dealer for $119.00 and installed the 35 watt HID kit with 4500k bulbs from DDM tuning for $32.00. It's pretty much a match for the HID headlights and looks awesome.
Could you post a pic to see the color comparison to the headlights?
Your factory HID bulbs will be 4300K and a 4300K HID conversion kit will be a near-perfect match for the fogs
Make sure you are using an HID relay, otherwise you may damage your factory electronics
Nick C.
Nick C.
have been looking at your products - plan to call soon to discuss. But, do you offer a light that would go into the CS fogs that would be a match to the HID's from a color standpoint? XML2 in cool white or perhaps XP80? Any mods required for these?
I will be putting the CS fog kit on, when I put on the Roush upper and lower grills that are sitting the closet at the moment. So, will loose the factory fogs, and install these in the lower bumper.
For those converting to the CS lower fogs that want plug-n-play wiring, we now sell the wiring adapters separately:
http://www.starkey-products.com/must...-h11-2013-2014
The Ford wiring included with the DR3Z-15200-AA kit is adequate, but some of our customers have said they don't want to cut factory wiring. Its also nice to have the option of returning the car to stock form in the future if needed.
Jason
Jason
Diode Dynamics
6/12/18 03:26 PM
Diode Dynamics
2/28/18 09:37 AM
