2010 hood scoop
Old Nov 27, 2011 | 07:47 PM
jamer109's Avatar
2010 hood scoop
I am having trouble getting a hood scoop installed on my 2010 mustang GT. The body shop tells me that this hood scoop is known for not fitting properly after they sold it to me and installed it. The addhesive is letting go and the front of the hood scoop is seperating from the hood. Has any one heard about this problem before?
Old Nov 29, 2011 | 07:02 AM
AirForcePonycar's Avatar
Scoops seperating isn't unheard of. What type of scoop is it? You can try taking it off, using an adhesive promoter on the scoop side and use some 3M doublesided tape from autozone etc. You can always bolt it in if you don't mind holes in your hood.
Old Nov 29, 2011 | 08:14 AM
dmhines's Avatar
If you want a scoop on a 2010+ then the Factory scoop is the way to go .. it's held on by 3M tape + 4 bolts + 5 fasteners ... lots of holes but it won't come loose.
Old Nov 30, 2011 | 03:54 PM
bones302's Avatar
you can't expect a stick-on hood to stay on if you're not going to bolt it on like the factory scoop does. It will only be a matter of time before that thing becomes a projectile.
Old Nov 30, 2011 | 04:07 PM
AzPete's Avatar
Yep...factory scoop is the only way. No issues to 100+mph.
Mar 30, 2021 09:29 AM
yabutt
Oct 23, 2015 01:05 PM
robjh22
'10-14 Exterior Modifications
Oct 9, 2015 02:49 PM
TerryD
Sep 28, 2015 11:48 AM
Ray11
Sep 25, 2015 12:43 PM
