random cylinder head temp spike, 2013 V6
Old Sep 10, 2013 | 10:46 AM
Manbo's Avatar
2013 V6
Just wondering what other sixxers are seeing for their cylinder head temps?
Normally Mine is between 96 and 99 Celsius (203-210 f) but randomly now I notice the temps just rapidly shoot up to 105 c (221 f) and then I baby the car to get it to go down eventually.
No bubbles in the coolant, no leaks I can see. Last time happened on not an overly warm day.
Can't really find what the accepted cylinder head operating range is anywhere for the cyclone engines. Anyone know or experience the same thing?
I'm thinking that if it happens randomly after a quick accel to get around traffic, maybe a hose is collapsing from vacuum.
Manbo
Old Sep 10, 2013 | 12:04 PM
CVH's Avatar
CVH
Originally Posted by Manbo
2013 V6
Manbo
I run between 203-208f constantly. Has it happened more than once?
Old Sep 10, 2013 | 09:35 PM
zbrewha863's Avatar
Ergh, cooling issues are a pain in the butt to troubleshoot. First, find out when it happens. Is it only when you accelerate hard? What (if any) mods are on the car?
Old Sep 11, 2013 | 09:10 AM
Manbo's Avatar
Yeah happened a couple times since I've started driving with the vehicle info on the info display on.
Definitely happened after a good pull, so I'm leaning towards vacuum pinching a hose.
I do haul *** on a regular basis, so haven't been able to nail down a pattern. Both times were during a moderately long drive (over 70km's) vs my 25km commute.
Only thing I had modded in the engine is Airaid CAI.
I'm not worried about it, but it's just something I'll keep an eye out for and if it happens on a cooler day, I'll be having them checking the coolant system.
Like you said, **** tough to troubleshoot. Guess I'll pop underneath and start looking for a pinched hose or any possible signs (not that I'll find one).
I guess I'm really just wondering what is considered "bad" when it comes to cylinder head temps, and when I should get worried if it start shooting up.
Thanks for your feedback!
Old Sep 13, 2013 | 02:15 PM
zbrewha863's Avatar
I believe the heads will start to warp around 130-140C, that was the danger zone on the S2000 I used to have. So you are safe, for now, but get that checked out in a hurry!
Chances are they will replace the water pump, thermostat, and housing first, then discover that didn't fix it, then kick **** for a while and try to figure out what to do.
If it's an intermittent issue with temp spiking, my guess is air bubble, I would ask them to do a leakdown test or test your thermostat to see if it is sticking.
Old Sep 13, 2013 | 02:25 PM
Ajcruz1's Avatar
I'm at 190-200 but usually it stays at 199. Its in this range even when I'm constantly getting on it during a drive.
Rando
Aug 25, 2021 11:12 AM
Gill5oh
Oct 6, 2017 10:50 PM
NC14GT
Sep 10, 2017 04:47 PM
Sep 30, 2015 07:02 PM
