Need help with the Mod Plan
I just ordered a Deep impact blue 2014 Prem. V6 with MCA pkg., glass roof, comfort pack and 3.31 gear. I know I want to lower it right away but I'm trying to decide between Eibach pro-kit which I have on my current mustang and love or the Steeda sport springs because they offer a little more drop which I want. Has anyone had springs from Steeda? Also, and this is probably my main dilemma, I want to have more power right away so I want to install cai, 73mm tb, and a tune. So I guess my main question is should I do the suspension first or power?
I am in the process of going with power mods as I thought it more important to have go. My end goal is to build a sleeper anyway. After those are completed if I deem it as necessary Ill start in on the suspension.
This is the plan of action I recommend:
1. 93 octane
2. Tuner
3. Gears
4. LCAs
5. CAI
6. Stickier tires
7. Springs/shocks/dampers
8. Driveshaft
9. Throttle body
10. Sway bars/strut brace
I have ported manifolds but haven't had time yet to install them so can't tell you yet how they would do. I would also recommend long tube headers but depending on how much you like or dislike noise, you may need to avoid them.
1. 93 octane
2. Tuner
3. Gears
4. LCAs
5. CAI
6. Stickier tires
8. Driveshaft
9. Throttle body
In order:
0) Window tint
1) Shocks/springs
2) Panhard bar or watts link
3) Wheels/tires
4) Sway bars
5) Brakes - at least get slotted/dimpled rotors, better pads, and steel braided lines, but if you have real money to spend, upgrade to baer, wilwood or brembo brakes (need at least 18-inch wheels for the big money upgrade).
6) Drive shaft
Now that the car can handle the speed, add the speed:
7) Tune/CAI
8) BBK Throttle body
9) Sleeper's ported intake
10) Headers
11) 2.5-inch cat-back system (with resonators)
12) If your car is an automatic, add the adaptive shifting reset mod described in the sticky threads at the allfordmustangs.com 2011+ V6 forum.
0) Window tint
1) Shocks/springs
3) Wheels/tires
4) Sway bars
6) Drive shaft
7) Tune/CAI
10) Headers
1. 93 octane
2. Tuner
3. Gears
4. LCAs
5. CAI
6. Stickier tires
8. Driveshaft
9. Throttle body
1. 93 octane
2. Tuner
3. Gears
4. LCAs
5. CAI
6. Stickier tires
8. Driveshaft
9. Throttle body
Yea I seriously considering the Steeda springs this time. I love the Eibach pro-kit but I want it to be a little bit lower than what they offer. Can you post a pic of your car?
If you want to be a little lower take a look at the Sport Lines or H&R supersports. We've started doing a lot more with the V6's. As far as tunes go, I'd really suggest going with VMP my customers have been extremely happy with his work. His response time is a little slow but his service is fantastic. Let us know if we can help you out, there are great opportunities to make your car a beast. I will agree with some of the comments and say suspension and a few brake upgrades should be first. Give us a shout: info@hypermotiveperformance.com and we'll set you up with a great package!
Jason
Jason
Jason
Jason
Sure..here's a couple of pics. This is with 19" wheels.
Thanks db2797 looks awesome! I think my mind is made up. Do you still have stock shocks and struts or did you change them out?
Yes I still have the stock shocks and struts. Honestly the car handles just fine for me. I do have upper and lower control arms installed though. So that helps too.
