Installed my Steeda Watts Link.
Old Jan 30, 2011 | 04:40 PM
David Young's Avatar
Talking Installed my Steeda Watts Link.
With it being in the high 60's today and rain with cold weather coming in a couple of days i installed my Steeda Watts Link. If you do your own repairs like brakes, water pumps, alternators, etc. you won't have any trouble installing a Watts Link. The directions were pretty good also. I went over railroad tracks and rough roads, no extra sounds . Too soon to post about the handling. Here is a picture of it
Old Jan 30, 2011 | 05:18 PM
nice work!
Old Jan 30, 2011 | 06:12 PM
Siber Express's Avatar
Looks Good David
Now I guess I will have to buy my own since it is not in the Spare bedroom any more
Old Jan 31, 2011 | 05:20 AM
How long did it take you to do the install?
Old Jan 31, 2011 | 05:25 AM
Thanks Glenn.
Your right Ken, the spare bedroom doesn't look the same without it . Ever since my dog (Chico) took up with you, things haven't been the same .
Old Jan 31, 2011 | 05:36 AM
Glenn, it was going so fast and smooth i had to stop and re-read the directions several times. Everthing fit perfect. I backed my Mustang onto 'ramps' and did it in my carport. It took me around 3 hours but i had several phone calls and took my dog out to pee a few times .
Old Jan 31, 2011 | 03:55 PM
Scott2's Avatar
David, looks great, please keep us posted on the handling once you have had an opportunity to put her through her paces.
BTW, what made you go with the Steeda Watts linkage over the Fays2?
Old Jan 31, 2011 | 04:23 PM
I went with the Steeda Watts Link because it is suppose to be more quiet than the Fays2 because of the type of bushings they use. I hear 0 extra sounds so far.
I did a few, hard high speed curves today. I run 35 psi in my tires. Feels like the rear tires are biting the asphalt harder now. I need to test more but looks like a few days of rain and cold temperatures are coming tonight .
Old Feb 1, 2011 | 01:33 PM
I removed it today because it is just too low to the ground for me . I'd hate to hit something on the highway and rip my rear-end off Here is a picture of what i'm talking about.
Only took around 45 minutes to remove.
Old Feb 1, 2011 | 02:09 PM
SoFlo Mustang's Avatar
Im new to car mods so dont flame... what do these do? Same idea as the stuff in the perfirmance package? Thanks
Old Feb 1, 2011 | 02:45 PM
newpony's Avatar
David,
If I recall correctly you didn't install lowering springs, correct? If that is true then don't think I can consider Watts-Link because I'm planing on lowering mine 1" and it will be worst for me.
Old Feb 1, 2011 | 03:00 PM
No Roberto, the axle won't be lower to the ground when you lower your Mustang. Just the body I think?
Old Feb 1, 2011 | 04:32 PM
karman's Avatar
Lightbulb Are you going to try again?
Originally Posted by David Young
I removed it today because it is just too low to the ground for me . I'd hate to hit something on the highway and rip my rear-end off Here is a picture of what I'm talking about.
As I look at the Fays2, it doesn't seem to hang that low.
Will you switch to that now?
Old Feb 1, 2011 | 05:07 PM
I don't know. All the pictures of the Steeda Watts link i've seen looks like it (axle clamp) wouldn't hang down that far. Pictures of the Fays2 looks like it (axle clamps) wouldn't hang down too far also. It does look like the axle clamps on the Fays2 "might not" hang down as far but its hard to tell from a picture of one not mounted.
Old Feb 9, 2011 | 05:17 PM
sam strano's Avatar
The Fays2 clamp does not hang as low as it doesn't have that adjustment slot. Here's a pic, and you can see that the clamp is about equal to the bottom of the differential housing....
Old Feb 9, 2011 | 06:41 PM
karman's Avatar
Thanks for the pic
Thanks Sam, that's what I thought.
Old Feb 10, 2011 | 11:09 AM
I cut out the adjustment slot on my Steeda Watts Link. Didn't need it . I think with the extra 1 1/2 inch of ground clearance, i might be able to live with it. I'm going to install just the axle clamp to see how much ground clearance i'll have. Its too cold outside to do it now It will be cleaned up and painted before i re-install it.
Old Feb 15, 2011 | 08:30 PM
wrxified's Avatar
Wow. Sounds like a hugely expensive test if this doesn't work out for you. Have other people with the Steeda watts link ever had a problem hanging it up on objects?
Jul 8, 2016 08:53 AM
mustangsally_
Sep 18, 2015 05:35 AM
SMOKE46
Sep 6, 2015 09:40 PM
Sep 2, 2015 07:33 PM
ustabawannab
Aug 5, 2015 08:32 PM
