3.73 gear noise
Old Jun 1, 2023 | 06:14 PM
Evan1726's Avatar
3.73 gear noise
Just recently had a 3.73 gear swap done but there seems to be a whirring noise on deceleration. Granted still breaking them in but should this be a concern?
File Type: mov
Old Jun 1, 2023 | 06:40 PM
05stangkc's Avatar
Installing Rear Axle gears is an Art. Only the Few Can Do Them Correctly. That Has Been My Experience During 35 Years Working at Ford Dealerships. Getting Bad Gears From the Factory in New Cars Has Been An Issue with Ford in the 8.8s For Years as Well. Gears Bad out of The Box Can Also Happen. I would Get Them Checked Out Sooner Vs Later. Comments Also Apply to 7.5 Diff in V6 to Lesser Degree as Far As Issues Observed.
I am Listing Shop Manual PDF for Refererence.
KC
File Type: pdf
Old Jun 2, 2023 | 06:20 AM
Bert's Avatar
Some gear whine is pretty common with the 3.73 gears. Some people say this can be eliminated if the install is perfect; however others say that there can be some whine regardless of how perfect the install may be.
I had mine installed by an installer with an excellent reputation around here, he double-checked the mesh pattern, and they still whine a bit. I called some other shops in the area to see if they might be able to do something with it, and they recommended that I go to the guy who already did the install, because he's the best around.
It should not do any damage, assuming it isn't horrible, but the noise can be a bit concerning/annoying. I'd suggest you talk with the installer about it.
Old Jun 2, 2023 | 05:53 PM
Evan1726's Avatar
I added a video of the sound. Let me know what you think
Added a video of the sound let me know if this is concerning or I’m just overthinking it.
Old Jun 2, 2023 | 07:31 PM
05stangkc's Avatar
I did Not Like What I Heard.
BTMO!
Everybody Chime In!
KC
Old Jun 2, 2023 | 07:34 PM
Evan1726's Avatar
FYI the humming sound is the noise.. the rest is the rocks from the road!
Old Jun 5, 2023 | 04:59 AM
Bert's Avatar
it is hard to tell from the recording, but that does not sound like "normal" gear whine to me; what I have heard is higher pitched than that ... I think that is worth a trip back to the installer, take a road test with him and ask him if that is "normal" for his installs
Old Jun 14, 2023 | 05:57 PM
mdb007's Avatar
Hey I just found this in another forum if this helps. "I did get a negative report from the installer concerning the Ford racing gear he said it had burrs on it straight out of the box. He said that it could cause the rear end to whine when you let off it but should go away after the break in."
Old Jun 14, 2023 | 09:04 PM
05stangkc's Avatar
How Many Miles are They Saying to Break In?
KC
Old Jun 15, 2023 | 02:40 PM
mdb007's Avatar
It didn't say other than run it until the sound goes away!
Old Jun 15, 2023 | 03:05 PM
Bert's Avatar
wouldn't that be nice (if the sound went away) ... let us know how that turns out
Old Jun 15, 2023 | 03:07 PM
05stangkc's Avatar
If It Were Me I would Check For Metal Shavings at 500 Miles.
BTMO,
KC
Old Jun 15, 2023 | 08:21 PM
m05fastbackGT's Avatar
And yet your installer went ahead and installed them knowing full well the gears have burrs in them anyhow? If it were my car, I'd be demanding a full refund, otherwise, my next step would be to schedule a hearing before a magistrate in small claims court!
JCStang
Ecoboost
Oct 29, 2020 04:02 AM
AS15
1994-2004 V-8
Aug 31, 2016 07:03 PM
Louvel17
Feb 17, 2016 08:41 AM
joeyw3704
Sep 1, 2011 08:47 AM
Rash
Feb 20, 2007 09:15 PM
