gear noise in neutral?
Old Feb 20, 2007 | 07:53 PM
Rash's Avatar
will gear whine (decel) or (pinion) bearing noise still be there in neutral?
Old Feb 20, 2007 | 07:57 PM
RadBOSS's Avatar
In netrual the input shaft and cluster gear and the idler gears on the output shaft for each speed (excepth 4th) will be spinning. They are not exactly silent, but I would not characterize the noise as a whine.
Old Feb 20, 2007 | 08:11 PM
Rash's Avatar
well, i definitely have some whine on decel (more of a flutter) that goes away on tip-in. Also goes away if I shift to neutral. I also have a hum/moan type sound above 25 mph, which is independent of throttle position or gear/neutral. I'm fairly confident the decel whine is the gears, i was mainly wondering if the hum could also be differential related.
Old Feb 20, 2007 | 09:15 PM
RadBOSS's Avatar
Usually pinion noise will be prevalent during acceleration or decel, while the mesh is under load. probably loader as load increases. It could be cyclic and / or speed dependent as well.
Rando
Aug 25, 2021 11:12 AM
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
Mr. V
Dec 24, 2016 02:57 PM
ricky1728
Feb 11, 2016 07:25 PM
Rando
Sep 30, 2015 12:28 PM
