3.31 rear gear install / speedometer adjust
Old Sep 21, 2015 | 09:41 PM
iceD's Avatar
As you mod along, you will need to tune it. That's the best way to get the most out of your mods. And eventually, you WILL need to tune it for certain mods like long tube headers, high gears, wide tire size. Or your car will run lean and the speedometer will be off.
Old Sep 25, 2015 | 10:37 AM
backin15's Avatar
I do not anticipate any mods like headers or cold air intakes that require a tune. I also want to keep my warranty intact, a factory gear installed by the dealer + no tune = no warranty issues.
Old Oct 2, 2015 | 04:18 PM
backin15's Avatar
Got a quote from the dealer, $1,267.00. They said they could do 3.55's for the same price. I asked about recalibration the speedo and they said it is done by changing the wheel sensors. Is this true?
Old Oct 22, 2015 | 09:21 PM
3point7's Avatar
No it's not true. There are only two types of wheel speed sensors, "front" and "rear". Or Front left, front right, etc etc if you go with Motorcraft parts but there is no such thing as a different wheel speed sensor for each application of gear ratio. Check for yourself on rockauto.com.
http://www.rockauto.com/
Old Oct 26, 2015 | 05:17 PM
backin15's Avatar
Thanks for the reply. That's what I thought.
Ecostang
Nov 3, 2022 08:50 PM
SpeedyJoe
18
Aug 23, 2015 02:42 PM
Jul 30, 2015 06:47 AM
killaz05
Jul 24, 2015 08:49 AM
