2011+ V6 Stock Spring height?
Just out of curiosity I googled what the stock front to rear ride height ratio was but no luck. Anyone know what the stock spring heights are on a 2011+ V6?
I'm looking to get a more rounded drop out of my car. I don't want the rear to be lower than my front end but I don't want it much higher either. I would like them as even as possible.
How low do you want to go? There are lots of options that will give you the angle you are looking for. Do a search on the 55d spring kit. These are a rear spring only option that does exactly what you're looking for. Also my eibach pro kit springs did a pretty good job of evening things out. I got about .75" lower up front and an inch in the rear.
Ok ya that's about what I'm looking for. Tighter firmer springs all around but with a slight drop in front and the rear balanced behind it. 55D ill take a look. Pro kit or something equal to it is what I'm going for.
Big-D
7/27/15 11:24 AM
