Wiring harness
Wiring harness
ok, I have a 2011 GT. It has the grill foglights. I put the CS front facia with foglights on it but have not yet hooked up the lights as I do not want to splice anything. I notice that on the 2012 that set up is now a factory option. I am trying to find the wiring harnes that hooks up to both sets of foglights and the switch if needed to make it all work. any help would be appreciated.
I want to get the same facia myself with the fogs.... Did u attempt to put it on yet? I plan on getting the roush or saleen grille to delete the grille fogs, I want to make sure the harness is the same and can reach the bottom fogs without having to splice as well
Ford makes factory harnesses to delete the grill fogs.
They're a few feet long and extend the grill connections down to the lower fascia without splicing anything.
When I had my 2010 GT and added the Roush front fascia and lower fogs, I added Roush upper grille which deletes the grille fogs. The stock harness was NOT long enough to reach the lower fogs in the bumper. Roush made extensions though so no splicing was needed. I would assume the CS style fogs would have a harness extension kit with the fogs. Maybe someone who has done this can chime in as to whether or not the extensions come with the CS fogs
If you go to the ford web site and build the car you can have both sets of fog lights. this leads me to believe that there is a wiring harness for it. if an option is not available on the web site it is usually not one that can be selected or it makes you change one of the options.
You can order the fascia as a "dealer installed accessory" but there is not factory harness that allows you to run them both.
Yes it was a pretty easy install. It comes with the harness that will reach. just not for both sets.
