Sponsored by:
Sponsored by:
Wiring harness
Old Sep 24, 2011 | 09:47 AM
SeniorPong's Avatar
Wiring harness
ok, I have a 2011 GT. It has the grill foglights. I put the CS front facia with foglights on it but have not yet hooked up the lights as I do not want to splice anything. I notice that on the 2012 that set up is now a factory option. I am trying to find the wiring harnes that hooks up to both sets of foglights and the switch if needed to make it all work. any help would be appreciated.
Old Sep 24, 2011 | 11:25 AM
LEwis26's Avatar
There is no stock harness for both lights. From the factory it's either lower fogs or grill fogs.
None of the factory cars come with both sets of fogs.
Old Sep 24, 2011 | 11:30 AM
MyStang2010GB's Avatar
Correct
Old Sep 24, 2011 | 11:31 AM
Gtstyles2's Avatar
I want to get the same facia myself with the fogs.... Did u attempt to put it on yet? I plan on getting the roush or saleen grille to delete the grille fogs, I want to make sure the harness is the same and can reach the bottom fogs without having to splice as well
Old Sep 24, 2011 | 11:37 AM
LEwis26's Avatar
Ford makes factory harnesses to delete the grill fogs.
They're a few feet long and extend the grill connections down to the lower fascia without splicing anything.
Old Sep 24, 2011 | 11:40 AM
When I had my 2010 GT and added the Roush front fascia and lower fogs, I added Roush upper grille which deletes the grille fogs. The stock harness was NOT long enough to reach the lower fogs in the bumper. Roush made extensions though so no splicing was needed. I would assume the CS style fogs would have a harness extension kit with the fogs. Maybe someone who has done this can chime in as to whether or not the extensions come with the CS fogs
Old Sep 24, 2011 | 08:51 PM
SeniorPong's Avatar
If you go to the ford web site and build the car you can have both sets of fog lights. this leads me to believe that there is a wiring harness for it. if an option is not available on the web site it is usually not one that can be selected or it makes you change one of the options.
Old Sep 24, 2011 | 09:00 PM
LEwis26's Avatar
Go to a dealer and try to order it that way. It's impossible.
You can order the fascia as a "dealer installed accessory" but there is not factory harness that allows you to run them both.
Old Sep 24, 2011 | 09:03 PM
SeniorPong's Avatar
Originally Posted by MyStang2010GB
Correct
Yes it was a pretty easy install. It comes with the harness that will reach. just not for both sets.
May 3, 2026 05:42 AM
RCooke08GT
Feb 19, 2017 03:03 AM
Fedupdave42169
Oct 23, 2015 09:58 AM
mx5jhb
Sep 30, 2015 04:44 PM
