Who's Sean Hyland?
Who's Sean Hyland?
I see they have an Eaton blower kit out already for the 5.0.
500 RWHP on 91 octane.
http://www.seanhylandmotorsport.com/
1 Post
The standard pulley for the Saleen S197 kit is 4 psi, which was good for 388 on mine. If these things are running the standard compression you're not going to go much higher than that and still get a warranty.
Looks like a pretty straight forward kit.
Check out the welded intake (between the throttle body and the SC). Those curves and the weld are neither cheap nor unfinished. That's some of the nicest fab work I've seen in a long while.
![](http://www.seanhylandmotorsport.com/images/2011supercharger/SHM-010.jpg)
![](http://www.seanhylandmotorsport.com/images/2011supercharger/SHM-003.jpg)
May look a bit weird because of the rounder edges, but in no way is it cheap. SHM wouldn't put his name on the line with cheap aftermarket stuff. That i know for a fact.
