Sponsored by:
Sponsored by:
Vortech install cometed... Questions?
Old Jul 26, 2014 | 05:44 PM
shayner's Avatar
Have posted before several time about doing the install and now it's finished.
What I'd love to know if this is normal... As Im driving and taking it very easy the blower is making a constant noise..... Kind of sounding like my front brakes are squeaking like mad.
Also in second gear if I punch it my exhaust backfires which leads me to believe detonation but I can't tell, there's so much noise.
Now driving normal the vacuum is around 16 to 20 and in 3rd let's say and I'm half peddling it goes up to 0 to 3....is this normal?
I am afraid to give er and make problems.
Someone ease give some advice... Thanks in
Advance.
Attached Thumbnails Vortech install cometed... Questions?-image-204721171.jpg
Old Jul 26, 2014 | 09:27 PM
NacsMXer's Avatar
Being an internally gear-driven centrifugal supercharger, the Vortech is going to make a constant whine whenever the engine is running. Totally normal. The pitch of the whine will change with engine RPM.
Regarding the backfiring, this is probably due to improper A/F ratios. I personally wouldn't go wide open throttle with it until you can get a good tune for it. If you get into the throttle and hear a rattling sound from the engine, get out of the throttle immediately. This is what detonation sounds like.
The vacuum readings on your boost gauge are also normal. It will take a good bit of throttle to get the gauge to go to 0 and into positive boost. Boost will climb higher and higher in line with your engine's RPM. The higher the RPM, the more boost.
You have spent a good bit of money on a quality blower kit for your car so I would advise you to not skimp out on a good tune to keep things safe. Get a dyno tune from a reputable tuner if you can. Best of luck.
Old Jul 27, 2014 | 09:40 AM
shayner's Avatar
Thanks for the info....I have a tune to be done by steeda soon.
Until then it taking it easy then for sure.
That whistle is going to take some time to get used to though.
Old Jul 27, 2014 | 10:29 AM
Tron84's Avatar
I just got done with a vortech install on mine.
Yes the noise is normal, the BOV is constantly dumping boost when you see vacuum, that is what you are hearing.
The tune by far is the most important and critical part of the install. If not done correct things can go bad real quick
Old Jul 27, 2014 | 10:53 AM
shayner's Avatar
Originally Posted by Tron84
I just got done with a vortech install on mine. Yes the noise is normal, the BOV is constantly dumping boost when you see vacuum, that is what you are hearing. The tune by far is the most important and critical part of the install. If not done correct things can go bad real quick
That's another thing that makes me nervous...
things going bad. There's lots of experience at steeda though and I've never heard of things going south just good reviews.
Old Jul 27, 2014 | 12:23 PM
Tron84's Avatar
I tried a Steeda tune when I was NA. It was garbage.
I wouldn't let them even look at my car now.
You should stick with one of the well known tuners for forced induction (Lund, AEM)
Old Jul 27, 2014 | 02:52 PM
shayner's Avatar
I tried a Steeda tune when I was NA. It was garbage. I wouldn't let them even look at my car now. You should stick with one of the well known tuners for forced induction (Lund, AEM)
Nothing but good things said in the area I'm in about steeda....but all have roots style blowers though....mmmm.
Old Jul 27, 2014 | 04:16 PM
Tron84's Avatar
Id suggest going over to the svtperformance forums.
There is a lot more knowledge over there as far as every type of power adder.
Not trying to knock steeda, that was just my experience. I rarely hear of someone that is FI using a steeda tune.
Old Jul 27, 2014 | 04:56 PM
shayner's Avatar
Seems I have further issues...
What's your inlet air temp reading?.....I just looked at mine and it's reading 80f.... What the "F"!
How's that possible with having a inner cooler...
It's 78f outside right now.
Old Jul 27, 2014 | 05:08 PM
Tron84's Avatar
Easy, compressing air makes it hot.
You will see temps just over 100 degrees after a good pull. Without the intercooler they would be much much higher.
Old Jul 27, 2014 | 05:10 PM
shayner's Avatar
No kidding...you have have been a great help dude... Thanks for all the info.
You mentioned other places for tuning but it won't help me, I'm in toronto.
Old Jul 27, 2014 | 05:12 PM
shayner's Avatar
Id suggest going over to the svtperformance forums. There is a lot more knowledge over there as far as every type of power adder. Not trying to knock steeda, that was just my experience. I rarely hear of someone that is FI using a steeda tune.
I'll check it out.
Old Jul 27, 2014 | 05:54 PM
Tron84's Avatar
You sure Lund or AEM wont tune it? It's all remote tuning so you would think you could be anywhere in the world.
Old Jul 27, 2014 | 06:15 PM
shayner's Avatar
No dyno though...
Old Jul 27, 2014 | 06:20 PM
Tron84's Avatar
Don't need a dyno, all done on the street.
It's actually the preferred method with the new cars since they come with factory wide band o2 sensors.
Real world loads and the ability to nail down all the drive ability aspects is what makes it great.
Old Jul 27, 2014 | 06:33 PM
shayner's Avatar
[QUOTE="Tron84;6833341"] You sure Lund or AEM wont tune it? It's all remote tuning so you would think you could be anywhere in the world.[/QUOTE
I just looked at there site and your right, they can set me up with a tune... All I have to do is data log and share the info with them till we get it right.
I have heard Lund is really good but didn't figure it was possible for me to get a tune.
Wonder how long the process would take.
What tune did you go with by the way?
Old Jul 27, 2014 | 07:16 PM
Tron84's Avatar
I'm tuned by Lund.
They'll work with you until the tune is to your liking
Old Jul 27, 2014 | 07:18 PM
Tron84's Avatar
I made 718hp on a 3.47" pulley. In the process now of backing it down until I get a fuel system installed.
The dyno guy was very impressed with the tuning
Old Jul 27, 2014 | 08:36 PM
shayner's Avatar
I made 718hp on a 3.47" pulley. In the process now of backing it down until I get a fuel system installed. The dyno guy was very impressed with the tuning
Impressive... That's to the crank right?
Now how long did it take you as well to get the tune right and work properly at WOT.
Old Jul 27, 2014 | 08:39 PM
Troy, this is interesting... I always thought steeda was good. no?
Don't need a dyno, all done on the street. It's actually the preferred method with the new cars since they come with factory wide band o2 sensors. Real world loads and the ability to nail down all the drive ability aspects is what makes it great.
This is correct. After installing my smaller pulley and new intake, I went with JDM Engineering. Couldn't be happier. Remote tuned me from day 1. 3 revisions so far. Everything spot on. Getting on dyno soon so they can do the very last fine tuning. My afrs are already spot on tho.
To the op, so you're telling me you bought and installed a vortech kit with no tune???
