Sponsored by:
Sponsored by:
Upper control arm opinions
Old Jan 21, 2018 | 10:37 AM
Mr. V's Avatar
My upper control arm is starting to squeak. It's come loose before and I simply tightened it back up. I'm not sure why it comes loose. I'm thinking about simply upgrading it. I have a stock ucr now. I never changed it out of fear of sound issues. I changed my sways, , lca, and springs and struts with little to no effect on Sound. I'm thinking of going with Roush uca. I'm hoping someone has used that unit or can suggest other options. No increases noise is my primary concern
Old Jan 21, 2018 | 05:06 PM
EF1's Avatar
EF1
I have the Steeda adjustable uca with urethane bushings on both ends and haven't noticed any additional nvh.
Old Jan 22, 2018 | 05:11 PM
Mr. V's Avatar
How long have you had it? I am considering the non adjustable steeda
Old Jan 22, 2018 | 05:54 PM
EF1's Avatar
EF1
I installed around 3 years ago.
Old Jan 22, 2018 | 10:14 PM
Mr. V's Avatar
Thank you! You've put this part on my list. Does anyone else have experience with a ucr that they would recommend?
Old Jan 23, 2018 | 06:40 PM
Cavero's Avatar
I have the Steeda UCA. I noticed a little more NVH, basically a very light "hiss" from the differential, going down smooth roads with the windows up and the radio off. It was pretty easy to forget about though. I've had mine since 2008 and it's given me zero problems.
Before you go buying a new UCA though, why not try some blue locktite on the bolt?
Old Jan 23, 2018 | 07:58 PM
Mr. V's Avatar
I did try some loctite last time. I've had to tighten it twice in the last 5 years. I was thinking maybe lowering it had some effect on it or it might be defective. I haven't read about many folks having the same issue. I don't want to have to keep tightening it. If going after market doesn't fix the problem, maybe I'll stay with the stock
Old Jan 24, 2018 | 07:12 AM
Cavero's Avatar
My next thought would be replacing the nut & bolt. The bolt could be stretching.
There was an ok thread on allfordmustangs about why Ford considers suspension bolts to be one-time use only. The last reply was kind of interesting, saying that GM and Ford purposely mismatch the threads on the nut vs the bolt (slightly) to be a cheap alternative to locktite. Pretty quick read:
http://www.allfordmustangs.com/forum...uspension.html
Old Jan 24, 2018 | 07:17 AM
Cavero's Avatar
Another thought is that tascaparts shows those nuts as having nylon inserts -- those are only good for one or two uses. Then the nylon starts losing its holding ability
Old Jan 25, 2018 | 05:57 AM
Gabe's Avatar
I have the beefy BMR adjustable upper arm, the pics don't do it justice.
I replaced a non-adjustable Steeda unit which looked tiny in comparison.
As soon as I put it in I remember the rear-end feeling a little more controlled, a little firmer on launches.
I like it and would recommend it.
I also installed the BMR mount at the same time.
Old Jan 25, 2018 | 06:45 AM
Bert's Avatar
I don't have any specific recommendations, but something to think about while your on this topic:
If the car will see any road track use, the upper control arm needs to allow some rotation so the axle can articulate a bit as the suspension travels or when one wheel hits a bump and the other doesn't. If the UCA is too rigid it can cause binding with bad results.
I think there are some that have a joint in them to allow rotation but don't recall the make/model right now . . .
Old Jan 26, 2018 | 07:02 AM
Rog13GTCS's Avatar
Is it the bolt inside the cabin under the rear seat? Or the bolts under the car?
Old Jan 26, 2018 | 08:02 AM
Mr. V's Avatar
Under the car.
Old Jan 26, 2018 | 01:52 PM
Cavero's Avatar
I remember Ford saying when the S197 came out that's why the stock bushing on the UCA is so soft, to allow some articulation in the axle.
IIRC, Steeda's adjustable UCA is one of the ones that have that articulation point (but the standard UCA doesn't)
Old Jan 26, 2018 | 07:51 PM
tj@steeda's Avatar
Some good reviews here on AM's website:
https://www.americanmuscle.com/steed...-uca-1113.html
TJ
Old Jan 27, 2018 | 11:57 AM
dusman59's Avatar
I have done plenty of very hard cornering and have had zero problems with the Steeda UCA. I would suggest changing the mount as well for full benefit.
Old Jan 28, 2018 | 04:01 PM
5LHO's Avatar
I've had both the Roush and the Steeda. The Roush was absolutely no NVH. The Steeda has some slight NVH, mainly transmitting sounds of clunking 2 piece DS more.
The Roush piece in my stick 2012 MGT, in concert with UMI poly lowers and a slick tire, 1.6 60s on the otherwise stock BBP suspension. N/A, tune only, 11.91 at 115.
The Steeda piece does about the same, on the same suspension, although my new car is a 14 auto with 100 nitrous assist. Good for 11.3 at 120.6.
So, I can heartily recommend both your choices.
Old Feb 19, 2018 | 12:50 PM
Ponywars's Avatar
i have a roush uca in my 12 gt and it completely got rid of wheel hop and zero nvh over stock!!!!!!!!!!!
Old Feb 21, 2018 | 11:57 AM
scott9050's Avatar
I have the same and can agree with your assessment as well. Quality piece and much better driving characteristics.
Old May 1, 2018 | 02:53 PM
759Rider's Avatar
What about the diff bushing? I am not super impressed with the poly units, but they seem adequate.
I am liking the Steeda unit. $90, and it offers rotations. Seems like this combined with a poly bushing on the UCA would bind less.
Experience?
MaverickMLFD371
Dec 28, 2005 03:28 PM
O5GT
May 26, 2005 01:54 PM
