Sponsored by:
Sponsored by:
Tapping/Clicking noise in Gear 3, 4 and 5 with Steeda Triax Shifter
Old Feb 23, 2012 | 07:09 PM
2011BlackStang5.0's Avatar
Has anyone experienced a tapping/clicking noise that comes around 3K RPM with a Steeda Triax Shifter and Bracket. I recorded a sound clip but it is not clear on my iphone I will try to record it. It goes away when I put my hand on the shifter ****.
The noise was not there when I only had the shifter on, it is only after I installed the bracket with the RED bushing. Has anyone else experienced this?
Last edited by 2011BlackStang5.0; Feb 25, 2012 at 03:49 PM. Reason: I accidentally stated black bushing, the installed bushing is RED
Old Feb 24, 2012 | 09:40 AM
tj@steeda's Avatar
Hello Blackstang,
Please give us a call at 954.960.0774 so we can speak in more detail about the sound that you are experiencing. We will be able to get more information offline and help solve the clicking sound.
Thank You
TJ
Old Feb 25, 2012 | 07:51 AM
5LHO's Avatar
Yep, it's created by the bushing, not the shifter. I have that on my stocker with the bracket and black bush installed. that's why they gave you a softer red one, too. I'm going to switch out the shift **** and see if I can get at it that way. I like the precision of the black bushing.
Old Feb 25, 2012 | 03:56 PM
5LHO, I had incorrectly stated that I have the black bushing, I actually have the red bushing installed currently.
I called steeda and they will get back to me.
Old Mar 4, 2012 | 06:33 AM
Originally Posted by tj@steeda
Hello Blackstang,
Thank You
TJ
TJ, please see attached the sound file I recorded, if this is normal with the red bushing then I am OK with it, I will just have to find a softer compound bracket, because I do not plan to power shift etc with the car, but rather have the car quite.
Old Mar 4, 2012 | 06:44 AM
Recording of clicking sound
Could not get the file to upload in .WAV format, it is in mp3 format but had to zip it to be a valid file form. Let me know what you think.
You can distinctly hear the sound, it happens around 3K RPM in 3rd, 4th and 5th gear.
File Type: zip
Last edited by 2011BlackStang5.0; Mar 4, 2012 at 06:45 AM. Reason: Additional Information
Old Mar 4, 2012 | 08:30 AM
5LHO's Avatar
Are you still using the factory plastic thumb? I replaced the factory **** with an AM black resin **** and with careful install to ensure no pieces of the **** and spacer touch one another, it diminished the rattle somewhat, even on the black bushing. Plus it feels way more positive and direct now.
Old Mar 4, 2012 | 04:29 PM
I am using the factory ****, I will check out the AM ****. It is not too expensive so maybe worth the try.
Old Mar 18, 2012 | 02:35 AM
Well I ordered the AM **** and sound is much subdued. Thanks for the tip, I wonder if it is the weight of the **** that damps out the noise.
Old Mar 18, 2012 | 04:54 AM
2012GTCS's Avatar
Nice, I jut upgraded to an MGW shifter and have that same rattle at lower rpms. It's just the noise transfer thru the shifter is greater.
Does anyone know what ***** you can fit onto the "factory" threaded handle?! I'm not looking to have to buy another handle. Thanks
Old Mar 18, 2012 | 09:13 AM
You didn't get the mgw ****? I believe the mgw rod thread is same as stock. I have the black mgw btw.
Old Mar 18, 2012 | 11:39 PM
2012GTCS's Avatar
no didnt get a MGW ball. maybe I should. But i think you need their "aftermarket" threaded shifter arm...
Old Mar 19, 2012 | 06:22 AM
Hmmm I don't think so... I remember George telling me I can reuse my stock **** or throw theirs on.
Mr. V
Dec 24, 2016 02:57 PM
Rando
Sep 30, 2015 12:28 PM
Sep 16, 2015 06:44 PM
Sep 10, 2015 12:44 PM
robjh22
Sep 8, 2015 12:31 PM
