Sponsored by:
Sponsored by:
Squeak: Front LCA or STR.T oranges?
Old May 7, 2015 | 03:42 PM
cmplxlgc's Avatar
Exclamation Squeak: Front LCA or STR.T oranges?
I had Koni STR.T oranges installed mid-february, I've recently started having an ear-piercing squeak from the front, more-so the drivers' side. I don't notice any noise on steering wheel rotation. Noise is specific to bumps in the road, regardless of speed and even more so with speed bumps. The video i posted shows the noise on recoil. Any opinions?
View My Video
Old May 7, 2015 | 11:25 PM
Ponywars's Avatar
sounds like a bushing squeek for sure to me!
Old May 8, 2015 | 02:36 PM
Are you on the stock strut mounts? If so, were they reused and reinstalled correctly? No bearings missing, etc? Those will fail over time, esp if on lowering springs, etc.
Old May 8, 2015 | 02:46 PM
cmplxlgc's Avatar
No, brand new ford mounts were used when the struts went in - wanted to avoid mixing old and new in that area. Front LCAs and springs remained stock
Old May 8, 2015 | 07:56 PM
2012White5.0's Avatar
View My Video
I have almost the exact same issue, and so has another member on this forum. I bought mine March 1st. From what I have been able to find on other forums is that Koni had a bad run of struts first of the year. I called AM and I have replacements on the way that should be here on Monday. They also said it has been a common recent complaints with the STR.T's The other member on the forum said his issues was resolved with new struts.
https://themustangsource.com/forums/...squeak-536255/
This is the link to irl4512 who had is issue fixed.
https://themustangsource.com/forums/...inions-536696/
My post. Im taking the car to a buddys shop after hours on Tuesday so that we can put the new struts in. I'll let you know if this resolves it, but I had no issues before lowering, and started as soon as i drove the car after lowering.
Old May 8, 2015 | 10:43 PM
cmplxlgc's Avatar
guess i'll get the warranty work started with Koni, no sense in heading to Mustang Week with this situation... // Nice, but unfortunate to see i'm not the only one with this issue
just got home from work now, i'm just driving around the community at about 10-15mph and you can easily hear it over the exhaust and wind...
View My Video
RoushRS3
Sep 29, 2015 08:03 PM
AJ_Trevino15
Sep 28, 2015 07:51 AM
Evil_Capri
Sep 25, 2015 12:56 PM
DrVet
Sep 23, 2015 01:48 PM
