Sport mode
#41
Hey Steve, how are you liking the P spring and D-Spec combo? Seems like everyone favors the Koni Sports whever you look... curious as to why you decided to go with the Tokicos.
#42
I like them a lot actually. Took a little experimenting to get them dialed in perfectly, but that's part of the fun. I went with them because the Initial spring rate on the P's is a bit soft and wanted to be able to add a bit of ramped compression damping which these do, though the rebound is the primary adjustment. Found the sweet spot at 3.25 turns from hard on the front and 4.25 turns on the rear. Great ride and control at those numbers.
#43
Hey Steve!
#44
I saved a few Hundred $$ going with the D-specs. May prove to be foolish down the road, but I rarely keep cars long (as you know) and these work well for what I was trying to achieve.. Might be a few 5.0's at Z-Days!....
#45
I'll probably be keeping the car longer than I kept my Z (19 months) so maybe I'll just spend the extra bucks and get the Koni Sports. But they're on back order until sometime in March, so I guess I'll have to discuss it with Sam around then and make a decision.
CiniZter
25
4/28/16 05:41 PM
