shifter bracket bushing help
I just put in a AM short throw about two weeks ago. This doesn't come with a bracket bushing bit everyone here talks highly of them. Can someone please educate me on exactly what this will do. Will it make the shifting smoother? Will it fix that 2nd and 3rd gear sticking?
If it did then you need to take the car to dealer and get the fluid replaced with Fo Mo Co Dual Clutch Transmission Fluid. If not then make sure you are not triggering the shift solenoid. I believe the shift brackets only stabilize lateral movement and holds the lower assembly up. It does nothing to change shifting itself.
The bracket/mount does not solve notchy shifting, it just gives the shifter better support under load.
You can see the difference between the two in my pic. The one on the left is the stock bracket...just rubber and zip ties. Easy installation and a must have IMO on our cars.
FWIW: the UPR is the cheapest, but I returned it because the NVH was unbearable. The Steeda and Barton are about the same in price and quality, but I've read the Barton is harder to install. The Steeda also comes with 2 different bushings, one has little to no NVH(the one I prefer) and the other is more rigid.
Im debating this shifter and looking for others feedback (more than whats on thier website)
FYI: The Barton bracket is on sale this month at AM.com!
Yes I ONLY have the issue when shifting hard. The am shifter helped with this a little but it mainly just reduced the throw.
Like they said above, our Shifter Base Bushing will help eliminate the NVH assoicated with the OE base bushing.
Comes with two different durometer custom made polyurethane bushings to chose from; one low durometer for no increase in shifter NVH, and a high durometer for minimum compliance
PM me if you need any additional questions answered. Also, like Hytek said, you can give the Steeda Tri Ax a try and never worry about missing the 2-3 shift. It is a great piece and it is made in the U.S.A
http://www.steeda.com/store/mustang-...e-bushing.html
TJ
TJ
TJ
TJ
I installed the Barton yesterday. It was a more difficult job than I anticipated, but the results are excellent. My biggest worry is whether the 4 allen bolts that hold the plates and bushing in place will back out as a result of vibration. They are not the easiest bolts to access and tighten and I did not think to use Loctite on them. I guess I will have to check on them from time to time.
Mike
Mike
Mike
Mike
Santa brought me a Steeda Billet Shifter Bracket (Part# 555-7090) for my new Boss, even before the Boss arrived. I'm going to install it just with the OE Boss shifter, to eliminate flex during my spirited shifts.
Mike
The Barton re-uses the existing two bolts. However, it has 4 bolts that connect two plates in which the bushing is contained. It is what I consider to be a more solid piece than the Steeda, although more complex and more difficult to install. It is a really cramped space up there, especially with an X-Pipe in place. Either way, anything has to be better than that Mickey Moused stocker. Zip ties? WTF?
Mike
Sep 16, 2015 06:44 PM
robjh22
Sep 8, 2015 12:31 PM
