Sponsored by:
Sponsored by:
Redline MTL - Installed - Thoughts
Old Mar 29, 2011 | 02:49 PM
InsidiousGT's Avatar
Install...
- Pretty basic fluid swap. As always with tranny fluid it makes a huge mess, and its a pain in the butt snaking your fluid pump up to the fill hole. I attempted to reach it from inside the car with the center console removed but couldnt do it, so I had to jack it up.
- Plugs... mine were on so tight I had to use a 2 foot breaker bar to get them off. When they came off they made a loud POP as if there was lock-tight on there and I just broke it. However, I can't find it documented anywhere that they would put lock-tight on the drain and fill plugs. I put em back on and torque'd em to spec and no leaking... so I guess I'm alright.
- Fluid difference... the old one is most likely the QS. Its much thicker than the Redline and more orangy/purple color to it. Redline is a nice thin pinkish color. They both stink, so its hard to tell anything from smell. No shavings or chunks came out in the fluid, but I didnt put any magnet in it. (5/20/10 build date)
Shifting....
- Cold, I noticed the different right away. It shifted cold like it used to shift warmed up. (meaning: its a bit tough to shift and its a bit notchy, but I never got locked out of a gear).
- Warm, it shifts much much better. Much easier to get into gear than before. I wouldn't say it removed the notchiness completely, but it definitely helped.
- Due to my Barton shifter and bracket, it has a much "mechanical" feel to it. Its hard to describe. Its not quite "harsh" and its not quite "crisp". Just a more direct feel to shifting I guess. I wouldn't recommend the Barton to anyone unless they were going to also do a fluid swap. I really love the Barton much more now.
- No whine at all with this fluid. However, as others have posted, when I'm resting my hand on the shifter I get much more noise and vibration coming up from the tranny. I never noticed this before with the stock shifter+fluid. I don't really mind though, because it will get me in the good habit of not putting pressure on the shifter while its in gear.
Overall very happy I went through the hassle of doing this fluid change.
Old Mar 29, 2011 | 03:03 PM
white__stallion's Avatar
Good word...something I might try...which exact part number from redline did you use? I think I know but I don't want to assume.
Old Mar 29, 2011 | 03:08 PM
It doesnt say so, but MTL is only a 70W80 oil, there isn't more than 1 kind of MTL. Their other products are MT-85, etc etc
http://www.redlineoil.com/product.aspx?pid=45&pcid=7
Old Mar 29, 2011 | 03:43 PM
Ok...thank you.
Old Mar 29, 2011 | 03:50 PM
Ltngdrvr's Avatar
So, you're not worried about the warranty on the transmission?
Old Mar 29, 2011 | 04:20 PM
I think we all are with MT82's....but the problem is we are just as worried about premature wear and getting hung out by Ford...
Old Mar 29, 2011 | 04:22 PM
Meh, the Redline MTL meets the WSD-M2C200-C listed in the owners guide. So I figure I could talk my way into some stuff, clutch, etc.
Anything major... I only put about 3k a year on this car, so I figure if it didn't happen between 0-3000 it won't happen between 3000-9000. Plus, its just as easy to get stiffed by my dealer with a completely stock car than with a car with this fluid.
Old Mar 29, 2011 | 08:18 PM
89Turd's Avatar
How much fluid does it take?
Old Mar 29, 2011 | 08:52 PM
2.7 quarts. cost me about 40 bucks at a local shop.
Old Mar 30, 2011 | 06:50 AM
89Turd's Avatar
How do you know that it'll meet the Ford spec you listed? I looked around a bit but couldn't verify that it meets the spec.
hpb50
Sep 27, 2023 03:03 PM
Spiker52
Jul 4, 2018 06:34 AM
drmag
Sep 1, 2015 03:47 PM
tdf017
Aug 5, 2015 10:13 AM
ToddMcF2002
'10-14 Exterior Modifications
17
Aug 3, 2015 07:42 PM
