rear alighnment..NEED HELP!
i have a 2012 mustang with 3000 miles on it,i put eibach pro kit springs on it and changed the wheels and tires.i notice that the rear tire is sticking out about an 1/2 inch further than the other side.can any one tell me why or tell me how i can fix this? im thinking adjustable pan hard bar but not sure!
Yup. Kinda like this one.
http://www.bmrsuspension.com/?page=p...&productid=172
It's an easier install than most think. And adjusting the bar is very easy, just don't torque anything until you get it centered. Rubber coated gloves make rotating the bar a breeze. Use lots of red loctite. The passenger side nut is hard to reach and it may be easier to tighten off the car after you center it up.
I used ramps to keep the suspension loaded. I would recommend an alignment afterwards.
Originally Posted by drewzx3
How do you make sure it's perfectly centered?
This...and you'll get it closer than any dealer or any alignment shop since you'll be taking your time. It doesn't have to be perfect but you can get it within a 16th of an inch. Alignment shop can align the front to matchup with the back.
Rando
8/25/21 11:12 AM
9/16/15 06:44 PM
