Sponsored by:
Sponsored by:
rear alighnment..NEED HELP!
Old Apr 30, 2012 | 07:34 PM
gary muder's Avatar
i have a 2012 mustang with 3000 miles on it,i put eibach pro kit springs on it and changed the wheels and tires.i notice that the rear tire is sticking out about an 1/2 inch further than the other side.can any one tell me why or tell me how i can fix this? im thinking adjustable pan hard bar but not sure!
Old Apr 30, 2012 | 07:37 PM
11SHELBYGT500's Avatar
Yes, your panhard bar needs adjustment.
Old Apr 30, 2012 | 07:45 PM
gary muder's Avatar
so i would have to buy an adjustable pan hard bar?
Old Apr 30, 2012 | 07:48 PM
adrenalin's Avatar
Yup. Kinda like this one.
http://www.bmrsuspension.com/?page=p...&productid=172
Old Apr 30, 2012 | 07:58 PM
gary muder's Avatar
yeah that ones not adjustable!
Old Apr 30, 2012 | 08:17 PM
KillerGT's Avatar
Yes you will need a adjustable pan hard bar. The install is not too hard and the adjustment is pretty easy as well.
Old Apr 30, 2012 | 08:25 PM
Ordie's Avatar
thats why he said KINDA like that one... Yes all you need is the Adj Panhard bar. I have the BMR one.
Old Apr 30, 2012 | 08:59 PM
gary muder's Avatar
yeah i just ordered the bmr adjustable..thanks guys!!
Old May 1, 2012 | 06:41 AM
wproctor411's Avatar
It's an easier install than most think. And adjusting the bar is very easy, just don't torque anything until you get it centered. Rubber coated gloves make rotating the bar a breeze. Use lots of red loctite. The passenger side nut is hard to reach and it may be easier to tighten off the car after you center it up.
I used ramps to keep the suspension loaded. I would recommend an alignment afterwards.
Old May 1, 2012 | 08:31 AM
adrenalin's Avatar
Oops, posted the wrong link but fixed it.
Old May 1, 2012 | 09:12 AM
drewzx3's Avatar
How do you make sure it's perfectly centered?
Old May 1, 2012 | 10:31 AM
devildog1679's Avatar
Put a heavy bolt on string. Tape string to center of fender then measure distance from top lip of rim to string.
Old May 2, 2012 | 05:39 AM
This...and you'll get it closer than any dealer or any alignment shop since you'll be taking your time. It doesn't have to be perfect but you can get it within a 16th of an inch. Alignment shop can align the front to matchup with the back.
Rando
Aug 25, 2021 11:12 AM
kponypower
Jun 17, 2020 07:17 AM
Fords4Ever
Oct 30, 2015 09:07 PM
Evil_Capri
Sep 25, 2015 12:56 PM
Sep 16, 2015 06:44 PM
