Oil separator?
I have one and I love it. It is well designed and the looks the best out of all the separators. Plus the Engine accessories match it. I made some custom hoses so It installs like the JLT. Only wish they had 90" aluminum elbows.
Nice, I'm looking forward to getting mine!
I'm running the Bob's Ultimate oil separator. It is supposed to be one of the best designs as far as catching as much oil as possible. I like that it has a convenient drain valve on the bottom. The powdercoat and AN fittings also look super trick!
![](http://i60.tinypic.com/2crr3w2.jpg)
![](http://i57.tinypic.com/34fbq0k.jpg)
Here's my Moroso. Excuse the dirty engine bay, I'd just driven the car directly home from the dealer on Day 1...in POURING rain. Like, monsoon-grade rain. That's why I was installing stuff instead of out driving. I got the Moroso, coil covers, hood struts, GT500 mufflers and Boss quads all done right off the bat. All in all a solid weekend, all things considered. ![Smile](https://themustangsource.com/forums/images/smilies/smile.gif)
![Name: IMG_20140614_175939_zpsjqrwuucf.jpg
Size: 118.9 KB](https://themustangsource.com/forums/attachments/f800/189697d1501261186-oil-separator-img_20140614_175939_zpsjqrwuucf.jpg)
Hey TJ, I'm a little confused by the directions. So I have to cut 2 1/2 inch out of the hose? Is that correct. Also, it comes with 4 of the barbed fitting, 2 are black and two are silver, I can use either the black or silver fittings correct? Also, do I use the pcv hose provided or the one that's already on the car, they are the same hoses .
I have the Moroso myself, catches quite a bit of junk and the lines after the separator are always clean. Bob's and Moroso seem to be the most-recommended out there. I haven't seen any testing with the Steeda but it would surprise me very much if it wasn't good, based on Steeda's rep. I've been seeing it around a lot more lately.
As mentioned above, a datalog would show if you've got a vacuum issue because of it. If it's properly sealed with no leaks, you're better off with it than without it, but you'd probably be better still with a higher quality unit. Definitely worth mentioning to your tuner though.
#40
