Sponsored by:
Sponsored by:
Need some feedback of short throw brackets and shifters.
Old Mar 30, 2015 | 03:24 PM
14BlackGT's Avatar
Hi all. I'm thinking about getting the Barton short throw shifter and bracket (the one piece one). First question, does the bracket introduce vibration into the car? Has anyone gotten just the bracket and left the shifter stock? General opinions? I've missed a 2-3 shift even on a freeway onramp. Thanks!
Old Mar 30, 2015 | 05:05 PM
JoeMidnight's Avatar
I don't have a GT.... but, the concept and generalization is the same. I've experienced locked out in 2nd with the stock setup. I installed the barton short throw shifter and 2 post bracket, LOVE IT.
I just did both... might as well if you're going through the work of changing the bracket.
Old Mar 31, 2015 | 11:43 AM
boss man's Avatar
I'll make it easy for you...
MGW
Old Mar 31, 2015 | 12:01 PM
MGW
it really is one half dozen or the other and boils down to preference. I can bet you my car that if you drove it, you'd have no idea if it were one or the other. fortunately for you, I'm not a gambling type of guy
Old Mar 31, 2015 | 03:11 PM
MGW
LOL. I really need to count how many times I have to post the letters "MGW" in response to someone even THINKING about any modification to their shifter, etc.
After all this, I can't believe folks still ask what brand shifter improvements they should do. It's not even a question anymore. The answer is ALWAYS, MGW.
To the OP asking the original question, don't even think about it, just buy an MGW. Case closed. It's probably the best mod on my car. And I even have the "old" MGW version (2012).
Joe... not quite sure I agree with you there. I know a couple folks who had Barton's, etc, and they switched over to MGW, and it's night and day. I'm sure there is improvement over stock, but have you ever tried to shift an MGW? You might be surprised at how different (much BETTER) it is over stock OR a Barton, etc.
Old Mar 31, 2015 | 03:41 PM
Stevedotmil's Avatar
A guppy Mustang friend of mine I've been helping out has an MGW on order. I'm going to help him install it. If I like it versus the Barton I'm ordering one same day. LOL. I've just been waiting for someone close to me to have one so I can drive one to see the difference. Then the Barton will be for sale.
Old Mar 31, 2015 | 07:00 PM
nice! let me know your thoughts on one and the other! i know the Barton one has a shorter throw but, not by much...
I look forward to your honesty!
Old Mar 31, 2015 | 07:13 PM
I haven't. just figured that my car shifts the same and slightly better than my neighbors 2010 GT500... figured that its enough to put a smile on my face when he acknowledges it as well. its good enough for me I suppose.
Old Mar 31, 2015 | 07:45 PM
5.M0NSTER's Avatar
I have the Barton shifter bracket with the stock MT82 shifter. It helps with missed gears. The other MAJOR thing that helps with missed gears is driver mod. Slow down, don't rush it, don't jerk it. Deliberate and concise does it. Don't try to find 3rd or 4th. Let the centering spring find it for you.
I have 3.73 and even with the steep gearing the car rewards ~1s gear changes. If you do a consecutive upshifts it takes roughly a second for the RPM to drop down to match the next gear.
Old Apr 1, 2015 | 03:44 AM
GrabberBlue5.0's Avatar
http://www.moddedmustangs.com/forums...idding-me.html
Old Apr 10, 2015 | 03:50 PM
05PRMTX's Avatar
I have just the Barton 2 piece bracket. I thought it made a pretty big difference considering it was only $100. Shifts felt more solid and I dont miss 3rd or 4th nearly as often. It does add some noise though. A fair tradeoff in my opinion.
Old Apr 13, 2015 | 11:51 AM
sqidd's Avatar
MGW
This
/thread
Old Apr 14, 2015 | 08:17 AM
tom281's Avatar
Blowfish bracket with a Steeda shifter. Best of both worlds if you ask me.
The MGW is a fine piece no doubt but it's also pricey. Sure you get what you pay for yadda yadda yadda lol. But because some people have to have the best of the best and are always looking to upgrade, you can find deals on used equipment that people are selling to buy an MGW. I bought the Blowfish and Steeda units used for less than a new MGW.
Previously on my 2006 I had three different setups: Saleen shift block, Pro 5.0 shifter, and then MGW shifter. Out of the three back then I preferred the Pro 5.0.
Old Apr 14, 2015 | 09:39 PM
Varilux's Avatar
+1 on the Blowfish Bracket... mine is mated to a Ford Racing shifter.
Old Apr 15, 2015 | 08:36 AM
scott9050's Avatar
I have a plain old one piece Barton bracket that I spent $40 on. It firmed up the shifts and I have not missed a gear since. I ran it 8 times at the track last weekend with no problems shifting. It is a good temp solution if what you are worried about is missing gears and not as much about the notchy cheap nature of the shifter.
Old Apr 21, 2015 | 07:36 AM
Bandit79's Avatar
I've had my version 1 MGW race spec in for about a month now and wow! Couldn't recommend it more. Granted I've only driven stock and my MGW so I can't compare it directly to any of the others but the MGW Race Spec does two things the other shifters don't. It replaces the weak mounting arm from the transmission to the side of the shifter with a solid piece of billet straight on. This solves the problems people would use the blowfish for with other shifters. It also replaces the actual shift linkage with a solid arm. The stock linkage has two articulating joints that bind up and help give it that notchy feel.
The other options may be fine but for these reasons I think the MGW, the Race Spec at least is still the top dog. It's expensive but if you're willing and able to drop the cash I don't see why anybody would go with anything else.
Old Apr 21, 2015 | 11:26 AM
boss man's Avatar
I think whats also VERY Important in the 2 companies that you speak of..Blowfish Racing and MGW is the over the top support to all customers.
Simple reason>>> They build there product that they sell. Where others just $ell them.
I have the blowfish bracket and I am 100% happy. Whats nice about the Blowfish bracket is it gives you the CHOICE to run what ever shifter you like. I like that!
Old Apr 23, 2015 | 09:41 AM
^ that's a really good point. Buying something from someone who makes it themselves, and supports it fully. MGW/blowfish. FTW.
Old Apr 23, 2015 | 09:44 AM
I'm just curious if you got around to installing the MGW? is it worth the money over the lesser expensive Barton brand?
That was the deciding factor for me, I found the Barton shifter to be more affordable.
Lets be clear. "more affordable" doesn't mean inferior quality/product.
I would have bought an MGW if it were in my price range. I'm happy with what I have regardless
trackpack13gt
Jul 25, 2017 05:29 PM
yabutt
Oct 23, 2015 01:05 PM
boz
Oct 1, 2015 04:47 PM
Sep 16, 2015 06:44 PM
