Sponsored by:
Sponsored by:
!!NEED HELP!!steeda cai and bama tune
Old Apr 14, 2012 | 06:40 PM
gary muder's Avatar
i installed a steeda cai and bama tune,install of the cai went great..i installed the performance tune first!when you push on the throttle the response just falls on its face ond stalls out!i put back to stock then installed the race tune and the same thing happened!so i put back to stock again but afraid to drive the car because the instructions say not to drive with out a tune because it would be bad for the engine! has anyone had this problem,suggestions would be appreciated.
Old Apr 14, 2012 | 07:14 PM
2012GTCS's Avatar
Did you start the car after the performance tune but before the CAI?
Maybe try disconnecting the battery for a few minutes to reset, or am I thinking too old school lol
Old Apr 14, 2012 | 08:01 PM
gary muder's Avatar
no i installed the cai first then the tune then i started it up!
Old Apr 14, 2012 | 08:58 PM
holtywsp's Avatar
Call bama ASAP they can fix the stalling for you. Make sure everything is buttoned up tight and there is not an air leak
Old Apr 14, 2012 | 09:09 PM
kona stang10's Avatar
Or get your money back from bama and call steeda for their tune. I just did the same thing you did but I got a steeda 93 octane tune.. flawless powerful operation..what really sux is you cant drive your car until bama responds with a new fixed tune...good luck!!!
Old Apr 14, 2012 | 10:40 PM
ZackeryJc's Avatar
Hmm that strange.. I have the same cai and tune and never had an problem with it.. Call bama and make sure everything is tight and correctly installed with the cai
Old Apr 15, 2012 | 05:16 AM
going for broke's Avatar
Something isn't right with either the cai install or the processor code.
Check where the rubber sleeve slides over the throttle body, then also make door sure the map sensor is plugged in correctly. (u did pull it out of the factory air box I'm assuming).
Then check the other connections off the back of the cai tube. I had to get a longer length of hose to make one of the connections reach easier.
Old Apr 15, 2012 | 06:48 AM
gary muder's Avatar
i checked all my connections and everything is good,i called bama and they are not open!i need to go to work and now i cant drive my car...not to happy..does any one know if i drive my car for a day if it will hurt anything?i put the computer back to stock and seems to be running fine,but the steeda cai is still installed.
Old Apr 15, 2012 | 07:40 AM
Big Poppa's Avatar
I recommend putting your stock airbox and tune back on until you can get your tune problems sorted out.
Old Apr 15, 2012 | 07:56 AM
Old Apr 15, 2012 | 07:59 AM
gary muder's Avatar
i think that would probably be a safe way to go big poppa...thanks!
Old Apr 15, 2012 | 09:43 AM
Just change the stock air box out.. Takes like ten minutes
Old Apr 15, 2012 | 10:54 AM
GrabberBlue5.0's Avatar
Problems with a Bama tune? No surprise.
Old Apr 15, 2012 | 11:24 AM
gary muder's Avatar
I installed the stock airbox back in,I guess I will call bama. tomorrow.
Old Apr 15, 2012 | 12:24 PM
After all that, time for a drive!
Old Apr 15, 2012 | 07:28 PM
tj@steeda's Avatar
Gary,
Let us know if you resolve the situation with a call to Bama tomorrow. If you could post some pictures then we can get a better idea of how the CAI is installed. It sounds like you have gone over it and over it and made sure the connections are tight.
Let us know how it goes.
Best Regards,
TJ
Old Apr 15, 2012 | 10:29 PM
gary muder's Avatar
Hey tj ,I have a pic of the cai install in my profile.not sure how to post it on here!thankyou
Old Apr 16, 2012 | 10:37 AM
tj@steeda's Avatar
Outside appearance alone looks as if though the CAI is installed properly. Let me know what Bama says and if we need to dig deeper on our end, I can have the Tech's help out.
TJ
Old Apr 16, 2012 | 12:36 PM
You did install the custom tune and not the strategy tune right?
Old Apr 16, 2012 | 12:44 PM
gary muder's Avatar
i called bama this morning and they did a revision on the tune,so i reinstalled the cai and the tune!much better..seems to have woke the car up a bit!i thought there would be a crisper throttle response,but i guess not.still a slight initial
hesitation...but much better.
