Sponsored by:
Sponsored by:
MGW vs STEEDA TRIAX SHIFTER
Old Jul 11, 2014 | 09:00 PM
SMOKE46's Avatar
Thinking about the MGW shifter for my 14 GT, I heard it's a little harder to install than the Steeda can you guy's chime in on your experience and quality of these shifters. thanx
Old Jul 12, 2014 | 08:29 AM
A search will net you a lot more results. We've addressed this, seriously, over 20 times in the last year. Please use the search function as it will save you and us, a ton of time. Just type in three letters..."MGW". Hit enter. And spend some time reading.
What you'll find is an overwhelming majority towards MGW.
Case closed.
Old Jul 12, 2014 | 10:02 AM
Last1's Avatar
MGW. No question.
Old Jul 12, 2014 | 06:22 PM
lakeguy77's Avatar
Let me help you with that: https://themustangsource.com/f726/shifter-help-531435/
Old Jul 12, 2014 | 06:31 PM
typesredline's Avatar
People swear by MGW. It's extremely high quality and design. If you did the steeda shifter, you'd have to also get the bracket to be apples to apples.
Personally I have the steeda bracket only. I love it (red insert). If I did a shifter, I'd do steeda. Not bc I don't feel that the MGW would be amazing. But bc I would only want slightly reduced throws. Steeda does 20%. MGW does 30-35%. And Barton does 40% which IMO is WAY to much and also makes it super notchy.
Steeda is still quality stuff. So I'd consider throw reduction and not only quality and user feedback.
Old Jul 12, 2014 | 07:48 PM
DinoDoc's Avatar
I love my MGW
Old Jul 12, 2014 | 08:29 PM
Jay@Hypermotive's Avatar
Former Vendor
There is truly no comparison between the two, we ran the Steeda in our 2011 but have the MGW in our Boss and a few of our other cars, its night and day. MGW is a great shifter!
Old Jul 13, 2014 | 03:16 PM
SMOKE46's Avatar
thanx all
SMOKE46's Avatar
thanx lakeguy
Old Jul 13, 2014 | 04:49 PM
jmaStang's Avatar
Another testament: I've had my car for a little over a year and installed an MGW about two months in. The trans is still notchy, but I do not get locked out of gears anymore. I can slide right into third after wringing out second. I added a braided stainless clutch line and modified Whiteline mount a couple months ago, but these made a negligible improvement.
The MGW was not too hard to install, just tight on space and time consuming.
Old Jul 13, 2014 | 04:55 PM
Originally Posted by jmaStang
Another testament: I've had my car for a little over a year and installed an MGW about two months in. The trans is still notchy, but I do not get locked out of gears anymore. I can slide right into third after wringing out second. I added a braided stainless clutch line and modified Whiteline mount a couple months ago, but these made a negligible improvement. The MGW was not too hard to install, just tight on space and time consuming.
See I feel that the steeda bracket alone gave this same improvement. But it was <$100 and took 10 min to install.
Old Jul 15, 2014 | 12:01 PM
PaxtonShelby's Avatar
MGW is a fantastic piece.
Old Jul 16, 2014 | 08:53 PM
Fustang5.0's Avatar
I have the Steeda shifter now and it has a great feel to it paired with the Barton and whitline bracket...
But I bought a used mgw unit a few weeks ago and hope to install it this week to see what all the hubbubs about. Hopefully the throws don't feel too short for DD use.
Old Jul 17, 2014 | 07:37 PM
todcp's Avatar
I just finished my MGW install today and went for a ride. Holy crap!!! I can finally rip through the gears properly. This should have been my first modification. Outstanding change. I read all the comments and the actual product performance still blew me away.
My car also has a Whiteline Trans mount bushing that I cut off the middle piece due to excessive NVH. I did not notice any added NVH from the MGW shifter.
The install video from MGW was very helpful and needed. A bit of a pain, literally, to do this job on jack stands but not difficult if you take your time.
Old Aug 16, 2014 | 07:11 PM
madbill1's Avatar
I finally installed my MGW shifter today. Agreed it was a pain in *** to installed on ramps. Luckily I'm a skinny guy. Took me almost 4 hours. I took my time while watching the installation video. Definitely a huge improvement over stock.
Old Aug 21, 2014 | 10:17 PM
warmmilk's Avatar
Update? I'm in the same boat as the OP...
Old Aug 22, 2014 | 05:36 PM
65sohc's Avatar
Is the Steeda the same as the SR Performance shifter? They look identical.
Old Aug 22, 2014 | 08:12 PM
Len's Avatar
Len
They're not the same.
Old Aug 25, 2014 | 10:02 AM
tj@steeda's Avatar
If there is ever any confusion ... make sure you look for the proudly Made in the U.S.A. on the Steeda Tri Ax Shifter.
Best Regards,
TJ
Old Aug 28, 2014 | 01:34 AM
Former Vendor
Just so there is no confusion and that statement. MGW and both Barton are made in the USA.
