Sponsored by:
Sponsored by:
KONI STR.T + Steeda sport springs
Old Jan 27, 2013 | 09:24 PM
  #41
PaxtonShelby's Avatar
Thanks folks. Car won't be here for a few months, but it is nice to hear the good feedback on the STR.Ts and Steeda Sport springs.
Sounds like the PHB is a wait-and-see item. Install the struts and springs, and then see if the PHB is needed.
So...
What PHBs are you guys using? Is the main purpose just to center ( and keep centered ) the rear axle, thereby preventing any tire rub throughout the full range of suspension travel?
Old Jan 28, 2013 | 01:27 AM
  #42
Hani's Avatar
BMR adjustable PHB is commonly used. And yes, it is required to re-center the rear axle after lowering the car (more than 1" i guess).
http://www.bmrsuspension.com/?page=p...&productid=172
Old Jan 28, 2013 | 12:01 PM
  #43
Ponywars's Avatar
Will i FEEL an improvement with STRT shocks on a stock brembo suspension,just 55d rear springs,roush uca,frpp lca.
Old Jan 28, 2013 | 12:04 PM
  #44
fdesalvo's Avatar
Yes. These cars are considered underdamped from the factory and this shock/strut combo will definitely improve handling and feel. I'm installing these along with the Steeda Sports as soon as my 14 arrives.
Old Jan 28, 2013 | 12:08 PM
  #45
going for broke's Avatar
So...
The pan hard bar will only center the axle under static load, a watts link is required to keep the axle centered throughout the full range of suspension travel.
When you lower the car without adding an adjustable pan hard bar, you change the static height of the vehicle thus changing where the axle is centered versus stock.
Old Jan 28, 2013 | 12:15 PM
  #46
So - it would be better to just get a watts link instead of an adjustable PHB? Or is that overkill for a 95% street-driven GT?
Old Jan 28, 2013 | 01:02 PM
  #47
Yes it would be much better, but it would also be a lot more money. Overkill IMO for street car. I just wanted to point out the differences between the pan hard bar and what you thought it accomplished. The stock bar is one length, The aftermarket pan hard bar is threaded so that you can lengthen or shorten it to center the rear axle when it's setting static on the ground.
Old Jan 28, 2013 | 02:34 PM
  #48
tj@steeda's Avatar
Here is a video that we put together for the adjustable panhard bar ...
PM me or email me at tim@steeda.com if I can help with any questions or pricing.
Best Regards,
TJ
Old Jan 29, 2013 | 08:00 AM
  #49
FAST FRED's Avatar
http://www.youtube.com/watch?feature...&v=ftkQI6IGV8M
Best Regards,
TJ
I just recieved my Steeda adjustable Panhard bar and brace from you guys. I will be putting it on soon. I will be using Steeda Ultalite springs also.
Old Jan 29, 2013 | 08:32 AM
  #50
blairnr67's Avatar
Subd
Old Jan 29, 2013 | 09:56 AM
  #51
06blackvertstang's Avatar
Originally Posted by blairnr67
Subd
Looks like someone's going to lower their car soon haha
Old Jan 29, 2013 | 11:40 AM
  #52
Ponywars's Avatar
Will you feel a difference with an adj PHB on a stock ride height car?
Old Jan 29, 2013 | 12:01 PM
  #53
fdesalvo's Avatar
You'd be gaining benefits from a stiffer bar and bushings, so you'd likely see some improvement, but I can't tell you that it would offer much return on invest.
Old Jan 29, 2013 | 04:26 PM
  #54
Jay@Hypermotive's Avatar
Former Vendor
You'd be wasting your money getting an adj. PHB on a stock height car unless you're car is not centered from the start.
Old Jan 30, 2013 | 07:15 AM
  #55
JMac's Avatar
Same plan here. Still accumulating parts and waiting anxiously for spring. The Steeda parts all look very well made.
Old Feb 15, 2013 | 09:56 AM
  #56
inspite's Avatar
I installed Koni yellows and steeda sport springs on my 2013 gt 300a. I also used the maximum motorsports caster camber plates. My only regret is that I wished I used the steeda plates instead because the MM plates re-use the factory bearings. Yep, the factory ones that come apart when removed. Mine kept coming apart when I released the pressure from the spring compressor. I do like the extra adjustability the MM plates give though.
At first I just installed just the rear shocks and drove around for a week. Even that was a big improvement.
I am playing around with the adjustments and it is real fun to try different settings out. I didn't get the adjustable panhard bar, but may in the future if I get wider wheels that will make my off center rear end more noticeable.
The ride is awesome! Too stiff for my wife, but the roads here are so bad, as soon as spring comes, it won't be so rough. I think the ride is a great compromise for my daily driven mustang. I will keep the koni's on stiffer settings unless on a trip with my wife. The adjustments on mine should say,,, Less *****ing..........Full *****ing instead of soft/stiff.
Old Feb 18, 2013 | 06:15 AM
  #57
Stevedotmil's Avatar
HA HA...less or more..That's classic husband logic. I'm with you brother. Good review. These are also on my to do list.
Autotooner
Nov 24, 2017 12:42 PM
Sep 30, 2015 07:02 PM
GeoWett
Sep 30, 2015 06:40 AM
AJ_Trevino15
Sep 28, 2015 07:51 AM
Evil_Capri
Sep 25, 2015 12:56 PM
