Sponsored by:
Sponsored by:
JLT Oil Separator problem maybe ?
Old Feb 24, 2013 | 07:39 PM
stang8psi's Avatar
Had my jlt on ,y car since 50 miles and it has cought a lot of oil vapors that would have gone into the intake manifold. But when I did my supercharger install and boss intake manifold, there was a a pretty good amount of oil in the stock manifold! So I know it works just not as good as others. So I am looking for a better one and may try the moroso one or the endyn one!
Old Feb 24, 2013 | 10:58 PM
fdesalvo's Avatar
I installed my JLT today. Doesn't require a bracket and I love that it uses the stock tube material as Ford.
Old Feb 25, 2013 | 01:47 AM
Originally Posted by TheReaper
Keep wasting your money. If you are FI then yes you need it. I had no issues with my 4.6 and no issues with the 5.0 as far as oil in the intake plenum.
4.6 3V NA after just 15k. Excess carbon build up affects A/F ratio and can cause detonation. The 4.6 3V is known to have a high degree of crankcase evacuation.
I don't know about the 5.0.
I prefer to reduce carbon as much as possible and to remove this black, smelly mix of oil & unburned fuel vapors from the crankcase.
Old Feb 25, 2013 | 07:43 AM
fdesalvo's Avatar
^ Egads!!
Old Feb 27, 2013 | 01:17 PM
J Tennu's Avatar
OP... I can understand your concern for the JLT catch can being suspended between the PCV hose in such a manner. With engine motion caused from acceleration/deceleration, huge bumps, big potholes, etc., it just may pose a future problem.
With that said, I do like how the JLT's piece looks under the hood. The PCV hose appears and fits just like stock and, depending on which finish you choose, can be very inconspicuous under the hood. It's also convenient if you need to do a quick swap from the separator to a stock hose.
Bob's Auto Sports oil separator looks like a very good piece. It reminds me of the Moroso oil separator(in regards to having a support point), but in a much more feasible size to be positioned under our hoods. I also appreciate that they offer a choice of fitting upgrades for the separator.
Old Feb 27, 2013 | 09:45 PM
TheReaper's Avatar
I deleted those when I tuned my 07 and they looked nothing like that. I used the "A" word in my crankcase
Old Mar 2, 2013 | 11:00 AM
M88K's Avatar
Installed Bob's oil separator the other day. This is a very high quality piece, and it's great that it can be mounted to the strut tower.
Old Mar 2, 2013 | 11:05 AM
steven46746's Avatar
Nice, loving mine too!!
Old Mar 25, 2013 | 11:45 AM
Tucker's Avatar
Originally Posted by 2012GTCS
No issues that I've seen from my JLT but haven't looked in a while.
Only issue I had was with the fittings and was told they don't use plastic fittings while I was staring at a stripped plastic fitting. So basically I got blown off and they are still the same way.
You didn't talk to us I can tell you that.
We have threads all over about this and have been replacing any broken fittings with either aluminum or glass filled plastic to anyone requireng them.
Aluminum straight with a glassfilled 90* have been shipping in the oil separators since aug. 2011.
If you need anything give us a call.
As for hanging, the separator weighs 3.5 Oz's and will cause no issues at all.
We use them for street, drag racing and road course action without a single problem.
Easy on, easy off and a OEM look
Jay
Old Mar 27, 2013 | 12:56 AM
TommyV's Avatar
A guy on the SVT forum lined up the JLT and Bob's in series. The results showed a fairly significant amount of oil got past the JLT only to be caught in Bob's. That was enough proof for me to buy Bob's over the JLT oil separator.
Did the guy ever line up the JLT behind the Bob's? If not, it's a failed test.
Old Mar 27, 2013 | 08:18 AM
joey8's Avatar
I'm thinking about getting the bobs oil separator. At of you guys have tips for install. I'm really not the most engine savvy guy so some detailed info would be great. Also if I buy the separator from bobs does it come with all the parts needed for install? Bc I see you can order standard 2 or 4 clamps on the website. Thanks.
Old Mar 27, 2013 | 09:23 PM
I got the standard, it comes with everything needed, and the only real work is a bit of measuring and cutting. Very easy install.
Old Mar 27, 2013 | 09:26 PM
joey8's Avatar
Thanks for the heads up. I made the plunge and just ordered a carbon fiber finish bobs separator. How were the instructions? Easy to follow I'm assuming.
Old Mar 27, 2013 | 09:32 PM
Mine came with instructions for a 05-10 3v 4.6 but it installs essentially the same way and in the same place. Separator will bolt on left side under strut, unhook stock hose, do a little measuring and cut included hose, hook it all up and clamp it down, done.
May need to take new pics, these seem a bit blurry after uploading them.
Old Mar 30, 2013 | 09:34 AM
M88K's Avatar
Joey,
Like Steven said, it's a fairly easy install. Just take your time and you will be pleased with the results.
Here are some iPhone pics of mine to help you get an idea of the install...
Attached Thumbnails JLT Oil Separator problem maybe ?-image-3382291079.jpg   JLT Oil Separator problem maybe ?-image-4011651252.jpg   JLT Oil Separator problem maybe ?-image-1495914258.jpg   JLT Oil Separator problem maybe ?-image-3877439837.jpg   JLT Oil Separator problem maybe ?-image-2608878526.jpg
Old Mar 30, 2013 | 09:45 AM
M88K's Avatar
He will in the spring, but it's really not necessary. Just browse through the SVT forums on the topic and you'll see numerous posts where Bob's simply outperforms the JLT separator.
I do like how the JLT looks like a factory component and is so easy to install though.
Rando
Aug 25, 2021 11:12 AM
boz
Oct 1, 2015 04:47 PM
RoushRS3
Sep 29, 2015 08:03 PM
southern stang
Sep 26, 2015 04:19 PM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
