installing new exhaust.
Old 9/1/13 | 07:49 AM
CarBrah's Avatar
Originally Posted by BRADGTCS
the trick that will save you the most time and headaches is when you drop the mufflers drop them from the brackets. so what you do is loosen the connecting tube clamps on the pipe. Then start with loosening the bracket bolts from the chassis. One they start getting loose you can shift the mufflers to get the harder to reach bolts. Once you disconnect all the brackets 2 per muffler you can then drop the muffler Assembly. Then you can use some wd 40, silicone or lithium grease to pull the brackets of over the spearheaded end of the muffler. I swapped mine in 30 minutes each.
thanks for the advice!
Old 9/1/13 | 04:26 PM
toxxxic13's Avatar
The hardest part of the exhaust install for us was getting the **** stock exhaust off. If I do it over ever again I will pay someone LOL
FromZto5
75
10/5/15 02:27 PM
9/10/15 12:44 PM
jim010
9/7/15 02:40 PM
SMOKE46
9/6/15 09:40 PM
Quick Reply: installing new exhaust.
