Sponsored by:
Sponsored by:
GT Fog to Driving light conversion...>>
Old Jan 6, 2011 | 12:10 PM
Modshack's Avatar
Fogs are basically pretty worthless unless you 1) live in an area that gets fog, or 2) like to run with those lights on for show.
Decided a set of dedicated driving lamps would be much more appropriate for night running. Had a set of glass Hella 500 series lying around. Bought a spare set of fogs off Ebay to modify for $20. Basically I removed the factory lens, mounted the Hella reflectors in those housings (retaining the stock adjusters) and remounted in the car. Just finished so haven't tried them at night yet, but the conversion might be of interest to some:
Some more pics: http://public.fotki.com/ttschwing/m-...-driving-ligh/
Start by hacking up the OEM lamps (remove lens)
Mounted the Hella lamps in the OEM housings
Rewired the stock bulb plugs to the H3 bulbs for a plug and play to the OEM harness:
Mounted the assemblies on my Eleanor grill:
Dual 55watt H3 bulbs and true driving lenses should reach out a bit better on those dark roads..
Old Jan 6, 2011 | 01:30 PM
Timeless's Avatar
Those fogs look familiar.
Looks nice.
Now, I would be interested in making my fog lights in my CS fascia match my HID lights.
Old Jan 6, 2011 | 01:55 PM
93CobraGuy's Avatar
Nice job!
Old Jan 6, 2011 | 02:14 PM
Modshack's Avatar
Looks nice.
Thanks! LOL...I actually ended up with 2 sets... Your old ones are still in the grill and sitting in my office!
Old Jan 6, 2011 | 02:17 PM
eliyarbrough's Avatar
I would love to do that! I run my fogs on all the time though! I just worry about if running them are still legal.
Can you post more pics from farther away of your Eleanor grill set-up? I like it a lot!!!!
I try to keep from driving @ night, too. My eyes get way bad. Maybe this isn't for me? Mine are just for show.
Old Jan 6, 2011 | 02:31 PM
Modshack's Avatar
dupe..sorry!
Old Jan 6, 2011 | 02:32 PM
Modshack's Avatar
Thanks.....Here's one .
More here:
http://public.fotki.com/ttschwing/m-...eleanor-grill/
Old Jan 6, 2011 | 03:19 PM
That looks pretty good! Maybe after I get mine paid for? Thanks!!
Old Jan 6, 2011 | 03:50 PM
CO_VaporGT_09's Avatar
I've got the PIAA driving light kit on my 2009 (http://www.amazon.com/PIAA-Ford-Must.../dp/B000GKIERK), stock fog location, and will tell you that they're bright and worthwhile, cover up the patchy pattern of the stock high beams well. But if you think people flash you now for wimpy stock fogs, it'd be 2-3x as bad with driving lights. Center mount might not be as bad for people thinking they're traditional driving/brights, but the amount of light put out is enough to blind oncoming drivers quite effectively.
Old Jan 6, 2011 | 03:55 PM
stangfoeva's Avatar
MOTM Committee Member
this reminds me how I turn on my fogs if somebody cuts me off
Old Jan 6, 2011 | 04:04 PM
Just be ready with that brake pedal; I slam the brakes when someone does that to me -- if they hit me, it's no doubt they're fault, and they ain't getting away with a hit-and-run.
But yeah, brights and driving lights go a long ways to letting someone know you're not happy, or that you're a dick if you just forget they're on.
Old Jan 6, 2011 | 04:08 PM
slidejob's Avatar
I did this back in 04' with a dual filament bulb. Check out the thread at my old name, which I can't seem to get into??
https://themustangsource.com/f691/fo...lights-395970/
Old Jan 6, 2011 | 04:11 PM
stangfoeva's Avatar
Old Jan 6, 2011 | 06:53 PM
karman's Avatar
Cool
I have the Hella 500s on my GT.
I switched the headlight wiring so they only come on with the high beams.
2 options now.
Regular head lights or DAYLIGHT.
Old Jan 6, 2011 | 07:24 PM
chutoyy's Avatar
Awesome. I think the same.
I might actually do this myself... Been thinking of what to do w/ my (useless) fogs...
Old Jan 6, 2011 | 08:32 PM
2 options now.
How'd you switch the lighting to do this?? I have the grille mount ones wired to a separate switch currently, and have yet to put some fogs in my lower fog light holes on the Heritage fascia. So those will function as the traditional fogs controlled by the stock pull switch. The driving lights are separately controlled that way. Wouldn't mind the way you say, though.
Old Jan 6, 2011 | 08:47 PM
karman's Avatar
Post
I just switched the terminals in the headlights, quick and dirty.
Downside...
I now have a "low beam" indicator in the dashboard lights.
I just leave "my color" on blue so I don't notice it.
I do like going between superbright and regular by just clicking the stalk.
Diode Dynamics
Jun 12, 2018 03:26 PM
Diode Dynamics
Feb 28, 2018 09:37 AM
defiance772
Oct 21, 2015 09:37 AM
awoychosky123
'10-14 Exterior Modifications
Aug 18, 2015 08:30 AM
Earlsays
Aug 5, 2015 07:10 AM
