FRPP X-Pipe......>
Originally Posted by ExVP
Tune may not be 'required', BUT, Mine ran lean when I simply swapped it with the H pipe. The sound softened abit. I had a tune run up for it on the fly on the dyno. Picked up 20 hp when it was done.
![Bs](https://themustangsource.com/forums/images/smilies/bs.gif)
Do explain how your car could run lean by simply just swapping the h-pipe for the X pipe. I could understand if u were talking about an OFF ROAD X. But just a plain x-pipe and the car ran lean?
I think you had an off-road X then. I swapped the H for my Corsa and have been running it for over four months with no trouble at all.
Originally Posted by RobDis
This is a complete noob question but i have to ask. Whats the difference between an offroad X and regular X pipe?
I don't believe I can explain in technical terms 'why' it went lean. When I say lean, that's relative to where the tuner had my car prior to this mod going on the car. I don't think it was dangerously lean, but definately not where my tuner wanted to see it for a street driven car. But he noted it had shifted all the way from idle to the top. After he was done playing with this thing he had the car settled at 407 hp. It was 386 prior to this session without the X-pipe. The car started at 368hp stock with 1500 miles. then went in with FRPP Sport mufflers and a drop in K&N and his tune with all this = 386hp. His tune was the biggest player in this 1st gain. Then the X-pipe went on 500 miles later and after it went on, the car felt and sounded different...and suspected something was up. Back in to see the tuner and found out there was more on the table to be had. About all I can tell you or anyone. May help with some folks decision making when going down these paths though...wouldn't you think?
The sound with an X-pipe will blend the exhaust, it will reduce the "cadence" of the sound. Rule of thumb, use X-pipe with flow thru mufflers and H-pipe with chambered mufflers. The sound may increase at higher rpms but at idle may be quieter than the stock h-pipe.
Off-Road pipe (x or h) will always be louder because they delete the cats and will require turning off O2 sensors with a tune.
hushpowers with x-pipe
just hushpowers
forward to 49 sec, I think without the x-pipe it sounds a little "truckish"
just hushpowers
It sounds like it could of been the tuner in this case making the car "lean".
A x-pipe will NOT make the car go lean just by replacing the H with the X.
OK! Got this in with a bit of work. The CAT side flanges did not line up precisely which required some prying and shifting to get the pipe clamped correctly. The factory H pipe has a lot more flexibility here. We almost decided to loosen a CAT so the alignment would be easier, but finally got it (with two of us working the alignment.)
Ran about 25 miles and here are the impressions. First, on Fuel, I run a Scangauge and monitor idle and partial throttle fuel trims constantly. I noticed no appreciable difference in these readings vs. the H pipe.
As noted above, the sound is a bit "softer" due to the exhaust scavenging being blended better. The car feels smoother both at idle and at higher RPM's. The cadence is much less noticeable. (I like)
As far as tone, as most have noted with an X-pipe, it is a bit higher. More "euro" which was basically what I was looking for. Seems a very good match to my Bassani Axlebacks. Somewhat quieter inside the car with the windows up and a little more of a "wail" when you get on it hard. Again smoother than with an H pipe. Feels a bit perkier..
Overall I'm happy with the change as it did exactly what I was looking for. Do it!
![](http://images59.fotki.com/v112/photos/5/7305/9684801/XPipe008-vi.jpg)
I'd have to agree with you ordinarily, with the X not affecting A/F ratio from an H. And yes, it can all lie in the tuners hand (good or bad). I can only pass on what he was observing and changing to get to my endpoint. The guy that just put his on just above my post had the exact impression I saw from adding mine, only I felt like I lost some bottom end punch at highways speeds pushing throttle in 5/6th. That's what mainly prompted me to go get things checked out. Still glad I did.
After a few more miles today, I'm liking this more and more Steve! Very smooth, feels faster, no noticeable low ind torque losses...4 thumbs up!..
Hmmm... I'm not so sure I'm sold on these.
So you lose low end torque from swapping the H to the X. And in doing that it gives the car more of a euro sound? I don't think that would be a good match with the Roush AB's, Im just looking to tone down some of the rasp.
#40
