FRPP Prototype Intake Manifold
Here is a pic of the prototype FRPP Intake manifold that Livernois Motorsports is running on their Mustang. The following picture was posted by Rick @ Livernois on another forum.
500+ HP N/A anyone?
500+ HP N/A anyone?
Needs to be more Astony
thats just the boss 302 manifold with a larger oval throttle body opening. notice the exact same shape, it just doesn't have the boss 302 peice stuck on top.
Not to mention, plastic is much easier to form, prototype and produce in quantity, as well as a lot cheaper. Plastic is generally smoother, with no casting flash or bumps on the inside to grind down. Plastic also isn't prone to corrosion like an aluminum or steel intake is. Finally, it is much lighter than metal - doubly good given its location high up.
Another area involving combustion where plastics have taken over is guns; many are made almost entirely out of plastic - except the barrel. There is currently no plastic strong enough to sustain repeated firing events. And although pistons experience a much softer and more drawn out combustion event, it has to go through billions of them over its lifetime; guns only have to realistically deal with a few hundred thousand at most.
I doubt it will happen soon. Plastic still has poor absolute strength compared to even aluminum. Plastic intakes will explode from a nitrous sneeze; metal intakes generally do not.
And as far as the plastic intakes go, they make them as light as possible and don't design them to contain internal explosions so it's no surprise that they would fail from a nitrous pop back.
I can only presume you're talking about, say, the Glock and other "polymer" pistols. With these guns it's only the frame that's made from plastic. The slide, barrel, firing pin and block ... are all metal. Even the frame itself is lined with metal where it meets the rails of the frame. The frame internals are all metal including the trigger group. Every single part that moves or sees friction in the gun is metal ... that's mostly every significant bit of the firearm.
It's like putting wood grips on a revolver and saying the gun is "almost entirely" made of wood.
lol.
What?
Lol, I can't stop laughing at you!!!! I mean, seriously!!! Plastic is what water bottles are made of, (minus Voss and other similar gay water brands in glass), polymer is what guns like Glocks and H&Ks are made of (to name a few). I would educate you further, but I believe my good buddy dascoyne has shed some light on your misinformation.
Way too long for a sig, just checked. :/, however, ----->
I don't mean to point out the irony of this post, but, just in case you weren't kidding: You do realize "plastic" is a polymer, right?
Polymer isn't an actual substance. It's a phrase used to describe many, many types of molecules. Using the word "plastic" in place of "polymer" is a common mistake, but not altogether wrong. What is altogether wrong, though, is trying to make someone feel stupid when you yourself don't even know what you're talking about.
LOL STOOOPID IT'S NOT PLASTIC, IT'S POLYMER LOLOLOL
