Sponsored by:
Sponsored by:
FRPP Prototype Intake Manifold
Old Sep 21, 2010 | 08:59 PM
FivePointO's Avatar
Here is a pic of the prototype FRPP Intake manifold that Livernois Motorsports is running on their Mustang. The following picture was posted by Rick @ Livernois on another forum.
500+ HP N/A anyone?
Old Sep 21, 2010 | 09:29 PM
hawkeye18's Avatar
But... but... where do you put the "5.0" decal on it?
Old Sep 21, 2010 | 09:37 PM
stangfoeva's Avatar
MOTM Committee Member
Old Sep 21, 2010 | 09:45 PM
Knight's Avatar
Needs to be more Astony
thats just the boss 302 manifold with a larger oval throttle body opening. notice the exact same shape, it just doesn't have the boss 302 peice stuck on top.
Old Sep 21, 2010 | 09:47 PM
Ltngdrvr's Avatar
Looks like the boss intake modified for the dual blade throttle body, just doesn't have the finned aluminum plates on top.
Old Sep 21, 2010 | 10:00 PM
FivePointO's Avatar
I know.. they took an awesome manifold and made it more awesome!
Old Sep 22, 2010 | 05:48 AM
Dragonacc's Avatar
This should do great things for the people out there that want to go high RPM NA with their build. Might be the route I go.
Old Sep 23, 2010 | 05:24 AM
Audioi's Avatar
Looks good but lots of plastic!
Old Sep 24, 2010 | 08:42 AM
KonaBlue5.0's Avatar
Plastic is not a bad thing for an intake manifold, especially for daily drivers. Heat soak is a killer for metallic intakes!
Old Sep 25, 2010 | 04:19 PM
hawkeye18's Avatar
Not to mention, plastic is much easier to form, prototype and produce in quantity, as well as a lot cheaper. Plastic is generally smoother, with no casting flash or bumps on the inside to grind down. Plastic also isn't prone to corrosion like an aluminum or steel intake is. Finally, it is much lighter than metal - doubly good given its location high up.
Old Sep 29, 2010 | 06:50 PM
Maxhenry's Avatar
So when do you think FRPP will release THAT CAI for the 2011 GT with their tune? Much better looking than just the K&N drop-in.
Old Sep 29, 2010 | 07:20 PM
Ltngdrvr's Avatar
I'm looking forward to that first production plastic engine block. It'll happen one day soon, already has been some experimental ones.
Old Sep 29, 2010 | 11:02 PM
hawkeye18's Avatar
I doubt it will happen soon. Plastic still has poor absolute strength compared to even aluminum. Plastic intakes will explode from a nitrous sneeze; metal intakes generally do not.
Another area involving combustion where plastics have taken over is guns; many are made almost entirely out of plastic - except the barrel. There is currently no plastic strong enough to sustain repeated firing events. And although pistons experience a much softer and more drawn out combustion event, it has to go through billions of them over its lifetime; guns only have to realistically deal with a few hundred thousand at most.
Old Sep 29, 2010 | 11:22 PM
Ltngdrvr's Avatar
Not to say that a plastic engine block wouldn't have piston liners like an aluminum block and possibly thread inserts. It'll happen sooner than you might think.
And as far as the plastic intakes go, they make them as light as possible and don't design them to contain internal explosions so it's no surprise that they would fail from a nitrous pop back.
Old Sep 30, 2010 | 02:06 AM
Minicobra's Avatar
That intake looks great, just needs some kind of finishing piece on top.
Old Sep 30, 2010 | 10:00 AM
dascoyne's Avatar
What?
I can only presume you're talking about, say, the Glock and other "polymer" pistols. With these guns it's only the frame that's made from plastic. The slide, barrel, firing pin and block ... are all metal. Even the frame itself is lined with metal where it meets the rails of the frame. The frame internals are all metal including the trigger group. Every single part that moves or sees friction in the gun is metal ... that's mostly every significant bit of the firearm.
It's like putting wood grips on a revolver and saying the gun is "almost entirely" made of wood.
Old Sep 30, 2010 | 10:36 AM
06GT's Avatar
lol.
Old Sep 30, 2010 | 11:37 AM
stangfoeva's Avatar
didn't even notice the Ford CAI. Can't wait for that to debut!
Old Sep 30, 2010 | 08:45 PM
alloybullitt7's Avatar
Lol, I can't stop laughing at you!!!! I mean, seriously!!! Plastic is what water bottles are made of, (minus Voss and other similar gay water brands in glass), polymer is what guns like Glocks and H&Ks are made of (to name a few). I would educate you further, but I believe my good buddy dascoyne has shed some light on your misinformation.
Originally Posted by dascoyne
What?
Way too long for a sig, just checked. :/, however, ----->
Old Oct 4, 2010 | 09:41 AM
I don't mean to point out the irony of this post, but, just in case you weren't kidding: You do realize "plastic" is a polymer, right?
Polymer isn't an actual substance. It's a phrase used to describe many, many types of molecules. Using the word "plastic" in place of "polymer" is a common mistake, but not altogether wrong. What is altogether wrong, though, is trying to make someone feel stupid when you yourself don't even know what you're talking about.
LOL STOOOPID IT'S NOT PLASTIC, IT'S POLYMER LOLOLOL
