Sponsored by:
Sponsored by:
Front left suspension making a "clunking" sound..
Old Jun 15, 2011 | 10:29 AM
Joe_in_Naples's Avatar
When I go over a speed bump I hear a clunking sound coming from the drivers side front end. What could be causing this?
Old Jun 15, 2011 | 02:51 PM
wproctor411's Avatar
The factory upper strut mounts is a possible reason. Have you lowered the car? I've not heard of a factory-height car making the popping noise but I could be wrong. Wait and see - someone with a similar experience will chime in I'm sure.
Here's a solution, but I like Steeda products, not trying to promote them or anything, just never had a problem or complaint with them. http://www.steeda.com/store/2011-up-...ut-mounts.html
""A great upgrade for anyone racing their car, running lowering springs, or wanting to rid their car of the popping sounds coming from worn factory mounts.""
Old Jun 15, 2011 | 07:05 PM
dan_h's Avatar
this actually appears to be a very commonly reported (on the other message boards) front LCA problem. Most folks end up getting it replaced at the dealership. I've got the same issue on my 2012...
good luck!
Dh
Old Jun 16, 2011 | 06:34 AM
Thanks for the replies, Im definately going to take her in next week. Sounds about right that it might be the front LCA.
Old Jun 16, 2011 | 11:42 AM
The Front LCA's can make noise?....a new one to add to the list of "sounds" I will keep checking for. So far I have been lucky with sounds coming from the engine, trans, or....whatever. I did have a tick noise from 200-500 miles but it went away. Dry weather and drag racing this summer should bring out the best in these cars (as far as finding noises and problems).
Old Jun 17, 2011 | 10:32 PM
J1000's Avatar
https://themustangsource.com/f726/sq...9/#post6090542
Squeak and clunk
Old Jun 26, 2011 | 01:32 AM
yokev's Avatar
I had a noise pop out of nowhere that sounds more like a 'grisel' sound. Can't describe it better than that..Definitely from the chassis/suspension, and it only sounds off when I'm taking off from a stop.
Old Jul 9, 2011 | 10:57 AM
rcm1802's Avatar
There is a service bullitan for the think sound over the speed bump. They are replacing lower control arms. My parts are on back order.
Old Jul 10, 2011 | 10:45 AM
Anthonynoz's Avatar
This is a stupid question but my friend told me that ford is actually changing these noisy control arms with the same exact one,would they do this or have they corrected the problem?I'm taking mine in soon.
Old Jul 10, 2011 | 01:30 PM
J1000's Avatar
There was a bad batch/run of parts from the supplier; mine has been great so far, since having them replaced a couple weeks ago.
Old Jul 17, 2011 | 07:22 AM
jayman33's Avatar
I have a clunk noise from take off. Almost sounds like the driveshaft but it has to be the front. I took it in and the dealer claimed "characteristics" of the car, it has gotten worse.
awoychosky123
'10-14 Exterior Modifications
Aug 18, 2015 08:30 AM
forceflow2
'10-14 Interior and Audio
Aug 4, 2015 08:02 PM
killaz05
Jul 24, 2015 08:49 AM
