Sponsored by:
Sponsored by:
Flowmaster Outlaw Slight Problem
Old Mar 11, 2014 | 09:15 PM
Watson91's Avatar
Hello all,
I'm new around here but looking for some help. I just bought a '14 GT Premium Oxford White with a few added goodies about two months ago. This weekend I installed Flowmaster Outlaw axle backs. I love the sound of these, but I have a slight problem with the driver side tip wanting to "float". The hanger is moving around in the rubber bushing, slightly, causing the tip to shift around a small amount. I put a clamp with set screw (Link To Image) on the outside of the hanger against the rubber to try to solve this problem. I have still noticed movement although it has been reduced. I fear that on a long trip the tip may shift enough to rest against the plastic cut out in the bumper and cause some melted damage. Has anyone experienced this before?
Old Mar 11, 2014 | 10:00 PM
Ltngdrvr's Avatar
Have Outlaws on mine and have never had an issue. All I did was leave the clamp on the over axle pipe loose until I had the tip exactly where I wanted it then tightened the clamp down and it has never moved.
Old Mar 12, 2014 | 11:34 AM
Watson91's Avatar
My process was the same as yours. My passenger side tip moves a little, but not near the movement the driver side tip has.
Old Mar 12, 2014 | 11:46 AM
Brandon302's Avatar
Get hanger keepers or whatever they are called, they were supposed to come with the kits but I never got any.
Old Mar 19, 2014 | 08:05 PM
shayner's Avatar
I didn't have an issue after my install as well.
If your clamps are installed properly there should be no movement.
Old Mar 19, 2014 | 09:00 PM
Ltngdrvr's Avatar
Is that what those little metal deals in the baggy were for?
Never used them, tossed them back in the box.
Old Mar 19, 2014 | 11:13 PM
Getportfolio's Avatar
Originally Posted by Ltngdrvr
Is that what those little metal deals in the baggy were for? Never used them, tossed them back in the box.
Yep. Some folks even wrap electrical tape around the hanger tips and insert into the rubber hangers. Same concept.
Rando
Aug 25, 2021 11:12 AM
Mpaps
Oct 11, 2017 08:06 PM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
