Sponsored by:
Sponsored by:
DOB Has Their GT550 Coyote Supercharger Kits Done
Old Apr 6, 2016 | 04:34 AM
sqidd's Avatar
Thought you guys would want to check this out.
556rwhp at only 10psi and 6750rpm's. Pretty stout for any kit. Very stout considering that they are only $4700 and even less if you want to build your own.
I'd bet there is 600+ in there at 11psi and 7250+rpm's.
Link:
http://departmentofboost.com/product...oyote-Manifold
Video:
Old Apr 6, 2016 | 06:32 AM
Illi73's Avatar
Gt 5.0 Tms Member
Wow, I like it. This seems pretty reasonable for us peeps on a budget.
Old Apr 6, 2016 | 06:58 AM
SpectreH's Avatar
Best intercooler for the positive displacement blowers on the market.
Old Apr 6, 2016 | 10:26 AM
Can't wait to get mine on!!! You guys think with the stage 3 Steggy ported blower and longtubes, I'll be at 600?
Old Apr 11, 2016 | 07:31 AM
sqidd's Avatar
No problem. You can probably do it without the ported blower.
Old Apr 16, 2016 | 06:12 AM
jcsix13's Avatar
just wish they came up with a base tune that goes with their kit that could be used so you could install it at home then drive it to get dyno tuned.
Jack
Old Apr 22, 2016 | 02:23 PM
Coyote5-0's Avatar
what would happen if you installed this kit and then tried to drive the car (gently) to a shop to get it tuned?
Old Apr 22, 2016 | 06:18 PM
Blown CS's Avatar
Buy one and let's find out. I'd say to just have it trailered to the shop.
Old Apr 22, 2016 | 08:46 PM
=HYPERDRIVE='s Avatar
What kind of potato was used to record that video?
Old Apr 23, 2016 | 05:55 AM
sqidd's Avatar
The 3v's were no issue driving to the tuner.
IDK about the Yote. The only hurdle I can think of is that because the TB wiring gets "split" so the GT500 TB can be run (with a harness) there MAY be something that needs to be switched over in the ECU to make that "active". But I don't think it would be an issue. The Yote TB 6 pin plug gets split into 4 and 2 pin plugs. Data is the same.
Old Apr 25, 2016 | 06:28 AM
Coyote5-0's Avatar
Oh wow... So a tuner would know about this?
Old Apr 25, 2016 | 07:01 AM
sqidd's Avatar
Yes.
Actually now that I think about it a tuner could give you a Roush base tune and that could be run. It uses a Roush harness for the TB and IAT sensor and those are the only things that are "particular".
When I tuned our S550 we used a Roush tune for startup and the first couple of tests (remote tuning).
MRGTX
May 12, 2016 09:30 AM
Joeywhat
Tire and Wheel Tech
19
Apr 21, 2016 06:46 PM
MustangMyWay
Mar 18, 2016 09:41 AM
mattism78
Mar 9, 2016 09:21 PM
