Comp Cams - 2011-2012 Mustang 5.0L Coyote Camshafts - AmericanMuscle.com
It's that time! We've gotten literally hundreds of inquiries about the 2011 & 2012 5.0L Coyote Mustang cams. The wait is finally over! They're in-stock and shipping. Can't wait to bolt these up to our 2011 Automatic to see what it'll do to our current 10.43 @ 130mph. We'll have dyno results and more soon!
![](http://ep.yimg.com/ca/I/mustangtuning_2159_1661579541)
Want some specs on them in the mean time?
Comp Cams Stage 1 XFI NSR Camshafts (11-12 GT / 5.0L Coyote)
• Advertised Duration: 267
• Valve Lift Int: .492
• Valve Lift Exh: .453
• Duration @ .050 Int: 220
• Duration @ .050 Exh: 223
• Lobe Separation: 126
• RPM Operating Range: 1500 to 6800
Comp Cams Stage 2 XFI NSR Camshafts (11-12 GT / 5.0L Coyote)
• Advertised Duration: 275
• Duration @ .050 Int: 228
• Duration @ .050 Exh: 231
• RPM Operating Range: 1700 to 7000
Comp Cams Stage 3 XFI NSR Camshafts (11-12 GT / 5.0L Coyote)
• Advertised Duration: 283
• Duration @ .050 Int: 236
• Duration @ .050 Exh: 239
• RPM Operating Range: 1900 to 7200
None of these are spring required cams, however ALL OF THEM need the phaser limiter kit, which we'll have up on the site soon.
Stage 1 & Stage 2 Cams are compatible with stock gears and stock converter, while the Stage 3 cams need a 3.73 or steeper rear gear ratio and long tube headers. Converter will probably be a good idea in Stage 3 as well, but we'll know for sure once we install them in ours!
http://www.youtube.com/watch?v=rGw4zou6Nws
I want to see the stage 3+ boss intake and rev limiter raised. I can't wait to start getting into mods on my car, but it will probably be a while before I go with any big power mods.... Oh well I'll live through everyone elses posts.
Is there a significance to those numbers? Other than the fact that the difference between each pair in the sequence (except the first pair) is a prime number?
8 - 4 = 4
15 - 8 = 7 (prime)
16 - 15 = 1 (prime)
23 - 16 = 7 (prime)
42 = 23 = 19 (prime)
Was that totally by accident?
8 - 4 = 4
15 - 8 = 7 (prime)
16 - 15 = 1 (prime)
23 - 16 = 7 (prime)
Hey guys I put the comp cams stage 3 n/a no springs required cams in my 2011 a few weeks ago. There is the good and the bad. I gained about 50 rwhp, but the cams at idle the lope isn't noticeable unless you know they are there. They can be tuned to sounds like the older 05-09 thumpr cams. But to get the most performance you won't hear any lope at idle. So if you want the performance it's worth it but if you are just wanting the awesome lope it's better for you to just get the steeda ghost tune or from someone else also and save your money.
The limiters basically keep the timing in a certain range based on the different cam that you get that way you don't have you valves crashing through your pistons because of the infinately adjustable timing on the stock cam. There was an article recently in 5.0 and Fast Fords about the install of these.
Detroit Steel
1/17/16 08:06 AM
MRGTX
7/21/15 02:08 PM
