Sponsored by:
Sponsored by:
Changing gears and mufflers wont require tune will it?
Old Sep 14, 2010 | 01:15 PM
elvism's Avatar
i dont think so???
Old Sep 14, 2010 | 01:32 PM
Ltngdrvr's Avatar
Only if you want the speedo to be correct.
Old Sep 14, 2010 | 02:35 PM
super6stang's Avatar
Gears yes, mufflers no...
Old Sep 14, 2010 | 10:16 PM
SynisterGT's Avatar
This.
Old Sep 15, 2010 | 10:38 AM
Lancel's Avatar
The speedometer will read incorrectly (not that they were incredibly precise to begin with, but still...) if you don't get a tune, but the inconsistency is pretty easy to spot and mentally adjust for if you are dead set against a tune. It all depends on how much you change the gearing.
For instance, let's say you change the rear axle gearing from 3.73 to 4.1. The deeper gearing means the speedometer will actually be reading faster than you're really going, as it still thinks you have 3.73s. To get the factor to multiply by to get your new speed, just take your old axle ratio and divide by the new axle ratio. In this case, 3.73 / 4.1 = ~0.91. Assuming this is the only change made, then your actual speed with the new gearing will always be 91% of what the speedometer actually reads. 60 MPH by the speedometer would be an actual speed of 54.6 MPH. You can round it off for mental calculation by just taking what the speedometer says, dividing by 10, and subtracting that from what the speedometer says.
30 MPH would be 27.3 actual
60 MPH would be 54.6 actual
120 MPH would be 109.2 actual
And so on. The formula holds true for going to shallower gearing as well, just keep in mind that doing that means you're actually going faster than what the speedometer says.
Aside from that I don't think there's any other issue with changing gearing.
robjh22
13
Aug 28, 2015 12:17 PM
davelev213
Aug 27, 2015 01:54 PM
glo106
Aug 11, 2015 08:29 AM
Bullitt 3309
Aug 2, 2015 10:20 PM
