Sponsored by:
Sponsored by:
Borla X-pipe doesn't fit?
Old Mar 25, 2011 | 08:29 PM
austin101385's Avatar
I just got my borla s-type catback for my 2011 GT. After getting everything loosened and unbolted, I went to install the x-pipe and it would not match up to the front pipes with the catalytic converters...and those pipes don't move much. The only bolts I could find to loosen are way up at the headers and there's no way I'm going to try to get to those with just a set of floor ramps.
The stock h-pipe has some type of flex connector that allows it to bend in and out, but the x-pipe of course is solid. Anyone heard of of this problem? I really wanted to install it my self since it's all bolt-on, but might have to take it to a muffler shop and get them to bend it?
I emailed Borla a couple of days ago, but have not heard a word from them. I would have thought that paying this much money, it would have been a perfect fit.
Thanks,
Austin
Old Mar 25, 2011 | 09:38 PM
hawkeye18's Avatar
Old Mar 26, 2011 | 12:04 PM
Yeah, that's what I might try
Old Mar 26, 2011 | 05:22 PM
The x-pipe is about 1/2" too narrow. I got my wife under the car with me to try again and pull the front pipe with the catalytic converters inward, but it does not budge much at all. I thought that it would/should just slip right on.
Old Mar 26, 2011 | 06:36 PM
hawkeye18's Avatar
If you have a hot air gun, you might try using that on the x-pipe to soften it up before you try spreading it. You can also bolt one side up, then use a c-clamp with some wood spreader bars to draw the two sides towards each other.
Old Mar 26, 2011 | 10:36 PM
wproctor411's Avatar
Reminds me of installing the exhaust in my old fox. Cut hands and bruised arms....lots of extra elbow grease.
Old Mar 26, 2011 | 11:57 PM
Swoope's Avatar
OP,
shipping damage? i would find it odd for a borla made product to be off by that much..
hot air gun not going to do it! muffler shop and flames in your future..
beers
Old Mar 27, 2011 | 03:01 PM
return it.....and what Scott said
Old Mar 27, 2011 | 03:03 PM
pony racer's Avatar
mine lined up with no issues.. then again a shop did it.. but i watched them the entire time..
Old Mar 27, 2011 | 07:23 PM
908ssp's Avatar
Did you loosen the header to cat bolts? Do that and the X pipe will go right on. If you don't return it but don't blame Borla. There is a ball socket at the end of the header which allows the pipes to move around.
trackpack13gt
Jul 25, 2017 05:29 PM
mlcinema
Oct 7, 2015 10:05 AM
RoushRS3
Sep 29, 2015 08:03 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
