Sponsored by:
Sponsored by:
Borla "ATAK" Rear Section or Cat-Back???
Old Oct 1, 2010 | 09:34 PM
J Tennu's Avatar
I went and did it... ordered the '11 GT! Now, I'm already shopping for an exhaust system to slap on this baby as soon as I get it. I'm pretty much set on going with the Borla "ATAK" set-up, but I need to know the pros and cons between their Rear Section(Axle-Back?) and Cat-Back systems. Sound-wise, is there a huge difference between the two? I'm guessing that the experts out there are going to tell me that the Cat-Back system will provide a bump in power and twist, but I should put it out there that I don't intend on putting this baby on a track of some sort... yet.
Thanks in advance for any assistance.
J T
2011 Mustang GT Premium - Sterling Gray, 6-Speed Manual Transmission, 3.73 Rear Axle
401A Rapid Spec with Black Leather & Cashmere Trim, Electronics Package, Comfort Package, Security Package, Brembo Brake Package, Glass Roof, HID Headlamps, and Rear Video Camera
Old Oct 2, 2010 | 09:36 PM
SynisterGT's Avatar
J T
Congrats on ordering your car. I am probably wrong on this but the AB alone have no drone in and I read somewhere the the cat back does. You will gain a bump in power with the cat back because it replaces the stock h-pipe. The cat back will be slightly louder then the AB but I am not sure how much louder.
Fully Loaded FTW. Have fun when you get.
Old Oct 4, 2010 | 07:23 PM
Double-EDad's Avatar
I don't think "cat-back" means you replace the stock H-pipe. THAT part is only replaced by the "X-pipe", which is a separate (and usually not cheap) component.
What the cat-back system will give you is smoother pipes between the H pipe and the mufflers, and I believe it eliminates a small set of stock resonators. It's these resonators that probably help keep down the drone on the stock system and on many axle-backs.
What I keep coming back to is that the Boss 302 literature says the stock 5.0 GT exhaust flowed well enough (to meet Boss goals), but Ford gave it slightly louder mufflers anyway (don't know what kind) and added the trick y pipes for unmiffled exhaust. So don't expect much from any aftermarket exhaust in terms of untapped power. That said, I think the stock system is way too quiet.
Old Oct 4, 2010 | 08:58 PM
m4a1mustang's Avatar
The factory H-pipe is post cats. The cat-back will replace it (typically with an X pipe).
The cat-back is going to be louder than the axle back because it deletes the factory resonators. How much louder I'm not sure.
Old Oct 5, 2010 | 10:08 AM
J Tennu's Avatar
Thanks, guys. I really appreciate all the help and responses. After reviewing countless posts and Youtube footage of different exhausts, it's looking like a rear section(axle-back) set-up for me.
I haven't been this anxious to get a new car in years. Twenty years, to be exact. My all-black '91 GT convertible was sorely missed, but I'm glad to soon be back into the fold!
J T
Old Jan 24, 2011 | 04:51 PM
SurfnSoCal's Avatar
Wanted to piggy-back on to this thread instead of starting a new one-
I too am set on the Borla ATAK. If I went with they AB set up, could I add an x-pipe later? I know on my 05, I did just that (AB and then added an X pipe).
Is there anything between the Xpipe and where the AB starts worth replacing? AKA the mid pipe?
Old Jan 24, 2011 | 08:09 PM
Guest123's Avatar
I have the s type borla catback system for my 2011 gt and it is louder than the axlebck and you can feel the extra 15-20rwhp that it gives you and since the cats are at the front right after the headers the cat back system gives you an x pipe very smooth over axle pipes and the axleback with 4 inch tips and the piping is all 3 inch!! A little pricey but well worth it! The atak catback system isn't much louder but is higher piched and raspier (which I don't like) that's my opinion hope it helps!
Old Jan 28, 2011 | 10:01 AM
southernmustangparts's Avatar
The new Borla systems absolutely rock!!!
I have a bunch in stock here at the shop.
If you are in the market look us up
2011 Borla Atak Exhaust Systems
Ken
Old Jan 28, 2011 | 01:50 PM
Flagstang's Avatar
Spam Connoisseur
I got هَبوب‎ed
catback = everything from the cat back
axleback = from the axles back
if this was answered my bad but I didnt read all the posts
Old Jan 29, 2011 | 08:36 AM
Ivan 5.0's Avatar
Sorry for being a noob but may someone please clarify? Im so confused, haha.
Do cat-back systems include the x-pipe (replacing the factory H-pipe)? I see people buying a catback system and then buying an x-pipe later? Why would they if a catback comes with an x-pipe?
Does an axel back system includes all of the piping after the factory H-pipe (including over the axel piping, muffler, and tip?)
... sorry, I'm just a bit confused here...
Old Jan 29, 2011 | 11:53 AM
Guest123's Avatar
You are right the catback systems for the 2011 gt come with an x pipe because the cats are right after the headers...but an axleback doesn't give you pipes from the factory h pipe back it only replaces the mufflers and tip and you will still have the ****ty factory piping from the h or x pipe to the axleback...and yes if you get a set of long tube headers and you already have a cat back exhaust the long tubes will remove your cats so you will need a new catted x pipe to complete the system....
Old Jan 29, 2011 | 01:20 PM
Ivan 5.0's Avatar
So is this diagram not accurate for the 2011 GT?
Old Jan 29, 2011 | 01:40 PM
Guest123's Avatar
No that diagram isn't accurate!!
Old Jan 29, 2011 | 09:08 PM
Ivan 5.0's Avatar
That's why I was confused as hell because I was going off of that diagram - and by reading posts it seemed like I was getting contradictory info
Old Feb 3, 2011 | 06:08 AM
Ethanjbeau's Avatar
Borla offers an xpipe with their catback systems where as magnaflow (what I have) does not. You have to buy it from them separately.
I don't know much about the other exhaust manufacturers though
Old Feb 3, 2011 | 06:39 AM
Ivan 5.0's Avatar
Ah, another reason I was confused. Haha. Thanks everyone for the insight
Rando
Aug 25, 2021 11:12 AM
kponypower
Jun 17, 2020 07:17 AM
Evil_Capri
Sep 25, 2015 12:56 PM
Airborne42
Sep 24, 2015 11:01 AM
50Cal
Sep 17, 2015 06:43 PM
