Boost gauge recommendations???
I'm pretty sure that autometer makes the Roush gauges.
Did you decide not to do the OBDII plug in gauge?
That one I posted the link to in your other thread says it reads boost as one of its gauges.
For my Vortech s'chgd '07 GT, I wanted to be able to see the needle move, so I skipped the ones that show vacuum and big boost numbers, and went with a VDO mechanical boost gauge that only reads from 0-15 psi so I could actually discern what psi I was at. Here it is mounted in a Roush vent cup....
![Name: CIMG0017.jpg
Size: 277.5 KB](https://themustangsource.com/forums/attachments/f800/196739d1501294052-boost-gauge-recommendations-cimg0017.jpg)
![Name: CIMG0013.jpg
Size: 274.3 KB](https://themustangsource.com/forums/attachments/f800/196740d1501294052-boost-gauge-recommendations-cimg0013.jpg)
Vacuum reading on the boost gauge is handy sometimes if you think you may have a leak but otherwise unnecessary.
_
Thanks for the information guys. I'm planning on finalizing my choice and order today. For what it's worth, I plan on using the Roush gauge vent pod so my gauge will have to be the circular 52 mm or 2 1/16 inch gauge
A Man Just Needs Some....
